pistonse30
    But chrome rims has that ring to it. This is great, hahaha
      I was referring to them as wheels long before vapes=) Just because industry used a term incorrectly doesn't mean that it is now acceptable. We are talking an assembly versus a component of the assembly here. That's like calling a light bulb a filament.
      I'm not following you... Because the industry that uses the product has historically called it something (has for YEARS and still does) - we shouldnt because you don't like it? :P
      You're partially correct - we are talking assembly components: A wheel assembly is made of a rim, tire, valve stem, etc...
      This is normally the time when someone chimes in with the "but da rim iz da edge - R u stuped?!?". The edge of a cylindrical object can be a rim (edge) however in the context of a wheel assembly it's a lip (a rim can be a 1-2-or-3 piece assembly of a barrel/face/lip).
      I've got bill of materials at work with Alcoa rims (from 30+ years ago through today) that call them rims - just because the current trend of today is to hate the term doesn't make it wrong.
      • andyhundleyA
        andyhundleyA
        andyhundley
        post-2784-0-75219700-1436455655thumb.jp
        The complete assembly minus the tire is called a wheel. Calling it a rim is like calling a car by one of its body parts ("hey if you want to drive my fender sometime, feel free") It just sounds ridiculous and just because so many have been calling it that for decades, it still doesn't make it right.
          That's the diagram I should have used=) Technically in a multipiece wheel, the lip and barrel would be the "rim". It is really a preference situation now since it has been misused so much.
          I'm not saying rim isn't correct now due to industry but it was used incorrectly for so long that it became correct/acceptable.
          People still use ain't even though it is not a word. That is similar to the wheel versus rim debate in my mind.
          Edit: Also Wikipedia states the same so it is the gospel: https://en.wikipedia.org/wiki/Rim_(wheel)
            I do not agree with the term "lugnuts". They do not grow on trees and they are not eaten by squirrels. Therefore they shall now be called "ANDYLOVESPENIS".... And I have a MS paint drawing to back up my opinion:
              Ultimate thread Jack. Went from turbos to Andy loving penis
                You should always ensure your ANDYLOVESPENIS's are tight prior to spooling your turbo.
                  That would definitely be an acceptable term for lugnuts=) Let's get that made into a standard
                    It was really awkward trying to explain to my woman why I was laughing so hard at my phone... You guys are fantastic hahaha
                      ALPINA wheels
                      Andy
                      Loves
                      Penis
                      In
                      North
                      Appleton
                        HAHA
                        Back on topic...for now.
                        Out with the old, in with the new!!
                        Brand new S54 oil housing on the left, S52 on the right.
                        Just ordered the 14mm to 12mm Vanos banjo bolt from VAC Motorsports.
                        That housing takes up so much room!
                          any reason you didn't use something like the champion oil filter relocation with a thermostat? Not real sure about the benefits of s54 housing, though. I just love the look of a hidden oil filter haha.
                            Less work, oem reliability and avoiding a lot of a/n fittings.
                            I definitely thought about getting the vac or Achilles units but $$$..
                              Vent oil temp gauge install:
                              Mark your spots to cut
                              Cut
                              Small cuts and some sanding of the upper and lower edges and she fits!
                              Now on to the fun part.
                              That's all for now, folks!
                                Going to spray the back portion of the gauge black to make it more incognito? Looks like you did a very tidy job cutting=)
                                  ^exact thoughts.
                                    Yes, I will. I have to figure out how to secure it in there. The spindle that came with it is too big. a bunch of electrical tape?
                                      Dab of silicone on the top and bottom where it touches the vent?
                                        Or just hot glue, firm but easy to get off if needed.
                                        • TCDT
                                          TCDT
                                          TCD
                                          Hot glue, silicone, electrical tape?  haha You guys are :D
