    Quicker updates!! Lol
      Ran into an issue with the intercooler, rad fan, oil cooler fitment as I planned it out. Just ordered a replacement intercooler and still have to figure out the room I have for a slim pusher style fan. It will be tight, but hopefully will work out.
      If only I had more time during the day there would be faster updates. I am trying to get at least one thing done every day I can before the picnic. We shall see.
        Been getting things done little bit at a time. A few bigger things have been getting the fan installed as well as fabricating custom mounts for the front mount intercooler. I also fabbed up the downpipe and got it over to kyle for welding.
        cb533acbca98abc94b57ae7de56ae0d2.jpg9574d08131350b6bb694d32eda6820b2.jpgcb8d09eeb4c946a9ca49e18666d2126e.jpg
          Getting close!!!
          Looks great!
            Thanks!
            Haven't forgotten about your driveshaft either. I'll be fitting it this week for sure.
              Thanks to leadballs I got the e30 driveshaft fitted, new CSB mounts in and everything bolted down/installed.
              Rear shifter carrier mount bolted up.
              Made an ignition coil mount.
              Intercooler piping fitted and painted.
              Waiting on downpipe to be welded so I can get it back, fit it up and measure out the extension that needs to be welded to flex pipe to mate with downpipe. Once that happens, I'll need that welded up along with the bov flange and a few misc things welded to the aluminum intake piping. Anybody able to do this super fast??
                Looking good!!!
                What are you running for coolant hoses with the M42 rad?
                  Water pump hose is e30, upper hose is euro 320i touring hose and the lower hose I will need to cut the curve off another euro 320i touring hose since the e30 lower hose kinks too badly
                    Dan the Exhaust man can weld short notice most of the time.
                      Got his number by chance?
                        Started cutting out the old seat mounts in order to make new ones lower in the car for the e30 sport seats. Otherwise they would have sat too high. Also preparing to do some floor pan surgery as well.
                        Last night I also made an adapter for my m50 tps to use with megasquirt.
                          DOOD you should have told me to send you the adapter when I sent you that TPS. I have an adapter saved from doing my brothers. Would be quick to machine another.
                            Its all good. The one I made does the job just fine. Thanks tho. Plus at the time you sent it, I didn't need the adapter as I was using the tps on my m10 turbo setup.
                              These will hopefully be in my hands in the near future ....
                                Havent updated this is a long time. After finally getting all my stuff welded by Dan the muffler man, I got the exhaust all buttoned up, charge piping installed, fuel hoses to fuel rail on, coolant hoses mostly on, vacuumed lines routed, started cutting out the rustly floors and also got the driver side seat mounts in and welded. this is the part of the build that really gets ya. A lot of small stuff that nickel and dimes ya till its finally done. It'll all be worth it tho
                                  Finished up connecting random coolant and vacuum lines. Started getting the wiring situated with soldering in the IAT sensor and doing a little modifying for the wideband, but ran into a problem. Turns on the o2 sensor plug and the oil pressure switch plug were cut off of the e30 harness I got. So I now have to cut open the harness to dig them out far enough to extend the wires. There goes my nice clean looking wiring harness. :(
                                  Anybody have a pic of where the oil pressure switch wire comes out of the harness, so I can search for any sign of what's left of that wire on mine? I found where the o2 sensor wires were cut.
                                    Got the o2 sensor wires pulled, extended and soldered up, cleaned up wires under the dash behind radio, mounted the megasquirt ECU under glovebox area along with wideband controller. Also wired up the IAT sensor.
                                    Next is adding engine oil, coolant, trans fluid, running the boost line for Megasquirt, siphoning out old gas and refilling with fresh gas and give it a test start.
                                    Hopefully tomorrow after going to brewers game or this week.
                                      Hell yeah!
                                        Friggin rights!
                                          Hell yeah friggin rights!
