    Looking good!!!
    What are you running for coolant hoses with the M42 rad?
      Water pump hose is e30, upper hose is euro 320i touring hose and the lower hose I will need to cut the curve off another euro 320i touring hose since the e30 lower hose kinks too badly
        Dan the Exhaust man can weld short notice most of the time.
          Got his number by chance?
            Started cutting out the old seat mounts in order to make new ones lower in the car for the e30 sport seats. Otherwise they would have sat too high. Also preparing to do some floor pan surgery as well.
            Last night I also made an adapter for my m50 tps to use with megasquirt.
              DOOD you should have told me to send you the adapter when I sent you that TPS. I have an adapter saved from doing my brothers. Would be quick to machine another.
                Its all good. The one I made does the job just fine. Thanks tho. Plus at the time you sent it, I didn't need the adapter as I was using the tps on my m10 turbo setup.
                  These will hopefully be in my hands in the near future ....
                    Havent updated this is a long time. After finally getting all my stuff welded by Dan the muffler man, I got the exhaust all buttoned up, charge piping installed, fuel hoses to fuel rail on, coolant hoses mostly on, vacuumed lines routed, started cutting out the rustly floors and also got the driver side seat mounts in and welded. this is the part of the build that really gets ya. A lot of small stuff that nickel and dimes ya till its finally done. It'll all be worth it tho
                      Finished up connecting random coolant and vacuum lines. Started getting the wiring situated with soldering in the IAT sensor and doing a little modifying for the wideband, but ran into a problem. Turns on the o2 sensor plug and the oil pressure switch plug were cut off of the e30 harness I got. So I now have to cut open the harness to dig them out far enough to extend the wires. There goes my nice clean looking wiring harness. :(
                      Anybody have a pic of where the oil pressure switch wire comes out of the harness, so I can search for any sign of what's left of that wire on mine? I found where the o2 sensor wires were cut.
                        Got the o2 sensor wires pulled, extended and soldered up, cleaned up wires under the dash behind radio, mounted the megasquirt ECU under glovebox area along with wideband controller. Also wired up the IAT sensor.
                        Next is adding engine oil, coolant, trans fluid, running the boost line for Megasquirt, siphoning out old gas and refilling with fresh gas and give it a test start.
                        Hopefully tomorrow after going to brewers game or this week.
                          Hell yeah!
                            Friggin rights!
                              Hell yeah friggin rights!
                                Fishboy and I are in an abusive relationship
                                    Well it's true. You better have it running
                                      It sounds dumb, but I went years without having a single funnel in the garage. Just never remembered to buy one. Then when you need one and realize you forgot to buy them again.... #%&*!
                                      Good luck with the first fire up!
                                        Hit the jackpot on oil! Couldn't resist the price!
                                          More details! What? Where? How much?
