    Things didnt go as quick and smooth as I wished. Looks like tomorrow will hopefully be the day the engine/trans goes in. Crossing fingers!
      The engine has landed!!!
        Looks really good!
        Should have came that way from factory
          Install harness, make downpipe, install coolant hoses, radiator and intercooler, install/modify driveshaft, patch floors, install rad. support section, make charge pipes, install hood and seats, check connections and fasteners, add fluids, load tune file, fire it up and go to the e30 picnic.
          Did i miss anything?
            Thanks for making my to-do list. I'm adding make a center support bearing mount
              Flat stock with two studs through it and welded to the unibody?
                That may work. Otherwise cut old mounts off and reweld in new location is the route most seem to take.
                  Looks awesome!
                  Sent from my potato phone
                    I ended up welding a flat piece of metal across the tunnel, then put in some gussets, and then cut the center section out and drilled the bolt holes. It's a PITA to keep everything flat, planar and level when you're dealing with little 2 inch long pieces of metal. Otherwise bolting the brackets to a spare CSB or equivalent jig would probably help. Good luck. Don't burn yourself while welding over your head.
                      Install harness, make downpipe, install coolant hoses, radiator and intercooler, install/modify driveshaft, patch floors, install rad. support section, make charge pipes, install hood and seats, check connections and fasteners, add fluids, load tune file, fire it up and go to the e30 picnic. Did i miss anything?
                      Core support section installed
                        Looks like you need an m50 TPS
                          I have been waiting for a text from you with a tracking number
                            M42 radiator installed.
                              Quicker updates!! Lol
                                Ran into an issue with the intercooler, rad fan, oil cooler fitment as I planned it out. Just ordered a replacement intercooler and still have to figure out the room I have for a slim pusher style fan. It will be tight, but hopefully will work out.
                                If only I had more time during the day there would be faster updates. I am trying to get at least one thing done every day I can before the picnic. We shall see.
                                  Been getting things done little bit at a time. A few bigger things have been getting the fan installed as well as fabricating custom mounts for the front mount intercooler. I also fabbed up the downpipe and got it over to kyle for welding.
                                  cb533acbca98abc94b57ae7de56ae0d2.jpg9574d08131350b6bb694d32eda6820b2.jpgcb8d09eeb4c946a9ca49e18666d2126e.jpg
                                    Getting close!!!
                                    Looks great!
                                      Thanks!
                                      Haven't forgotten about your driveshaft either. I'll be fitting it this week for sure.
                                        Thanks to leadballs I got the e30 driveshaft fitted, new CSB mounts in and everything bolted down/installed.
                                        Rear shifter carrier mount bolted up.
                                        Made an ignition coil mount.
                                        Intercooler piping fitted and painted.
                                        Waiting on downpipe to be welded so I can get it back, fit it up and measure out the extension that needs to be welded to flex pipe to mate with downpipe. Once that happens, I'll need that welded up along with the bov flange and a few misc things welded to the aluminum intake piping. Anybody able to do this super fast??
                                          Looking good!!!
                                          What are you running for coolant hoses with the M42 rad?
