813 Posts 31 Posters 0 Views 1 Watching
    Now to get the rest of the car looking that good=P
    I cannot wait to see this thing ripping
      Thanks guys! Yeah I used a good amount on that crank bolt sucker. Hopefully won't be a problem.
        Cut new grooves into the new injectors and got them on the rail.
        Remember kids, dont throw off the emperors groove ...
          Got the oil filter housing installed & clocked to clear the manifold, fuel rail and injectors installed, oil distribution block put on and the turbo oil feed line ran. Started fitting the turbo oil drain line too. Just have to cut the braided line to length and attach the other fitting.
            Do work!
              Just a couple more things to bolt on and hopefully the engine/trans will be in its new home this weekend.
              d6915b01f6528e306e327d351e085a3e.jpg52b5c4eb95a0a95c212b4d43412567a6.jpgad9571a8d7dd64b3c15971e6378d7c96.jpg
                Things didnt go as quick and smooth as I wished. Looks like tomorrow will hopefully be the day the engine/trans goes in. Crossing fingers!
                  The engine has landed!!!
                    Looks really good!
                    Should have came that way from factory
                      Install harness, make downpipe, install coolant hoses, radiator and intercooler, install/modify driveshaft, patch floors, install rad. support section, make charge pipes, install hood and seats, check connections and fasteners, add fluids, load tune file, fire it up and go to the e30 picnic.
                      Did i miss anything?
                        Thanks for making my to-do list. I'm adding make a center support bearing mount
                          Flat stock with two studs through it and welded to the unibody?
                            That may work. Otherwise cut old mounts off and reweld in new location is the route most seem to take.
                              Looks awesome!
                              Sent from my potato phone
                                I ended up welding a flat piece of metal across the tunnel, then put in some gussets, and then cut the center section out and drilled the bolt holes. It's a PITA to keep everything flat, planar and level when you're dealing with little 2 inch long pieces of metal. Otherwise bolting the brackets to a spare CSB or equivalent jig would probably help. Good luck. Don't burn yourself while welding over your head.
                                  Install harness, make downpipe, install coolant hoses, radiator and intercooler, install/modify driveshaft, patch floors, install rad. support section, make charge pipes, install hood and seats, check connections and fasteners, add fluids, load tune file, fire it up and go to the e30 picnic. Did i miss anything?
                                  Core support section installed
                                    Looks like you need an m50 TPS
                                      I have been waiting for a text from you with a tracking number
                                        M42 radiator installed.
                                          Quicker updates!! Lol
