  • andyhundleyA
    andyhundleyA
    andyhundley
    Can you take some better pics of the rear M3 seat fitment? Ive always been curious how they fit.
      All e30 coupe chassis are the same, aren't they? I don't see why an e30 m3 rear seat would fit a 325 any different.
        Got the ECS T3 solid gasket in the mail from @Frank_Mopar!
        Installed it with some copper RTV.
        Had to track down the Snap-On dealer to get a male 14mm allen socket for the differential fill hole.  Picked this up too and it's the bee's knees.
        The 14mm allen lead to this.  Please don't judge my washers:dontknow:
        The subframe diff mounting hardware. 16mm bolts and thick washers from a M-coupe if I remember correctly.
        Which lead to this.
        Oil change.
        I drained my crank case catch can that draws vacuum from the exhaust.  Nasty...
        Who wants to clean this up?!!?
        Some more pics of the e30 M3 rear seat.
        Washed off the garage.
        Goodnight.
          Disorganized garages drive me insane!!!!
          5s that shiz homie!
          Dat wang is pretty snazzy
            Waiting for burnout pics.
              ClassE said:
              Waiting for burnout videos.
              FTFY
                A little 1st gear video from your friend and mine, Snap, at Kyle's shop.
                https://instagram.com/p/0zpiG9NL7H/
                  Vertical video? cameraman should be shot.
                    Buttons down, dan
                      From my fender guy, KaMotors:
                      "I'm running 17x9 et10f w 245/40/17, 265 will fit rear with ultra-wides but much wider than a 245 on an e30 in the front will cause turn issues.  I believe 17x10 et20r I used for a customer but a bit had to be shaved off of soring perch."
                      A quick E30 shoot after I stopped by Snap's to pick up my freshly powdercoated wing flaps.
                      I took Snap for a ride and really gave it some beans.  I'm experiencing some break up at higher RPMs. Need to look into some different plugs (which Snap has so graciously done) and get a new tune from TRM. It's way too rich.
                        Not using HPS??
                          They don't make a 5w-40 in HPS.
                            Need to follow these instructions I think.
                            http://workshop-manuals.com/bmw/3_series_e30/325i_m20_tour/2_repair_instructions/33__rear_axle/14__locking_differential_with_bearings/2_ra__replacing_complete_locking_differential_%28type_m%29_final_drive_removed_-/
                              Love the pictures from today! Ive been showing lots of friends, family, and strangers its awesomeness.
                              And yes, we went for a ride and it was just like the "large chested scantily clad model goes for ride in fast tuner car" videos on youtube, except john's car doesnt have harnesses.
                              The thing is bonkers. Even with sticky BFGs it is losing grip in the 70-80mph range on the freeway. Oh and the Wilwoods did a fine job when we spotted Officer Friendly in the oncoming lane at or near triple digits.
                              Thanks again for the ride!
                                That was fun!
                                I wasn't too happy with the stopping power after the initial couple seconds.  I feel it faded a bit or my mind wanted it to slow down quicker.  Then again the rotors had some rust from sitting this winter.  #itgon3
                                  http://www.frsport.com/XXR-531-Reaxion-Wheel-17x10-4x100-4x4-5-20mm-offset-Hyper-Silver-ML_p_59527.html
                                  What do you guys think?
                                    I would pick 5w-30 or 10w-40 then. The hps is much better oil, anything api approved now is not that great, thanks epa. Their website basically says once out of warranty use hps, it has a better additive blend and higher zddp. Not trying to start an oil argument, just sharing what I have learned.
                                    Sent from my potato phone
                                      I appriciate the input!
                                      I've read a bunch of oil threads when I had my e30 m3 with the S14.  Those can get heated!!
                                        I dare someone to go over to www.bobistheoilguy.com and post a recommendation for some value brand oil to be used in a performance car application with 10k change interval.
                                        Actually dont, im not ready for the world to end yet.
                                          The dyno sheet from when I was at 13psi. Too rich??
