pistonse30
    Scooped up a new sub this morning.
    Wired it up to 2 ohms and installed it.
    My next project.  Installing a working glove box to hide all this.
    UPS just dropped of a small box!  Into the garage!!
      Got the DSSR in the mail.
      Had to grind down the selector end a bit to make it fit.  #Earl
      At home.
      The final piece to finish putting the interior back together.
      E21 mounts and the powder coated brace. #Snap
      Drive shaft bolted up, CSB preloaded, tunnel cover and powder coated brace installed.
      Harness from the PO.
      My E30 M3 interior from my old car.  I need to clean and condition everything.
      Where should I put these??  #Bassboy
        I love that zhp shift knob!
          Not on your car.
            ^or under the trunk or hood
              I forgot to mention that I found my Valentine 1 radar detector!  Super pumped about that.
              Update of the to do list:
              - Turbo T3 gasket (hopefully it will get delivered tomorrow).
              - Attach oil drain hose from turbo.
              - Add fluid to the diff and install.
              - Change oil.
              - Go over intercooler piping t-clamps to check for loose ones.
              - Swap trunk lids.
              - Take off roof rack.
              - Wash, wax and windows.
              The only thing I'm worried about is the clutch bleeding.  Pedal still feels a bit soft.
                I envy your ability to make such fast progress.
                  I'm trying to fly through everything while doing it right.  Everything that I can get a torque wrench on is tightened to spec, blue loc-tite is almost everywhere and new parts are being used 75% of the time.
                  I best finish soon as my hands have cuts all over them and the mechanic hand look is in full effect.  Kinda sketch when I'm in a suit showing prospective buyers houses...
                  • andyhundleyA
                    andyhundleyA
                    andyhundley
                    Can you take some better pics of the rear M3 seat fitment? Ive always been curious how they fit.
                      All e30 coupe chassis are the same, aren't they? I don't see why an e30 m3 rear seat would fit a 325 any different.
                        Got the ECS T3 solid gasket in the mail from @Frank_Mopar!
                        Installed it with some copper RTV.
                        Had to track down the Snap-On dealer to get a male 14mm allen socket for the differential fill hole.  Picked this up too and it's the bee's knees.
                        The 14mm allen lead to this.  Please don't judge my washers:dontknow:
                        The subframe diff mounting hardware. 16mm bolts and thick washers from a M-coupe if I remember correctly.
                        Which lead to this.
                        Oil change.
                        I drained my crank case catch can that draws vacuum from the exhaust.  Nasty...
                        Who wants to clean this up?!!?
                        Some more pics of the e30 M3 rear seat.
                        Washed off the garage.
                        Goodnight.
                          Disorganized garages drive me insane!!!!
                          5s that shiz homie!
                          Dat wang is pretty snazzy
                            Waiting for burnout pics.
                              ClassE said:
                              Waiting for burnout videos.
                              FTFY
                                A little 1st gear video from your friend and mine, Snap, at Kyle's shop.
                                https://instagram.com/p/0zpiG9NL7H/
                                  Vertical video? cameraman should be shot.
                                    Buttons down, dan
                                      From my fender guy, KaMotors:
                                      "I'm running 17x9 et10f w 245/40/17, 265 will fit rear with ultra-wides but much wider than a 245 on an e30 in the front will cause turn issues.  I believe 17x10 et20r I used for a customer but a bit had to be shaved off of soring perch."
                                      A quick E30 shoot after I stopped by Snap's to pick up my freshly powdercoated wing flaps.
                                      I took Snap for a ride and really gave it some beans.  I'm experiencing some break up at higher RPMs. Need to look into some different plugs (which Snap has so graciously done) and get a new tune from TRM. It's way too rich.
                                        Not using HPS??
                                          They don't make a 5w-40 in HPS.
