  4. 1991 318is M62B44 Build
268 Posts 27 Posters 0 Views 1 Watching
    i say its not worth fixing, thats pretty f'd up. i slid mine up a barrier once and it looked like that and was unfixable.  the cost of a straight one may be the same or even a little more, but i doubt they will get that perfect again. even on a straight one, the fog lights and brake ducts are a tight fit and rely on mounts which are on the valance itself, so if they dont get bent back to pefect, they wont fit anymore.
    secondly, looks like you need new fogs/brake duct/lip anyways, so you may find them all from one parts car for a better deal than separate.
      valance for sale:
      http://chicago.craigslist.org/wcl/pts/4895723427.html
      • CMartC
        CMartC
        CMart
        Trying to have a friend grab it for me Saturday, thanks!
        Excursion 7.3
        E30 LS1
          Do you happen to have a 540 radiator hanging around?  Looking for a non leaking one asap.
            JC you tease,  I clicked here thinking there was an update to be had.
            • CMartC
              CMartC
              CMart
              Only update is my garage is clean. I need to weld up a trans mount before the drivetrain goes back in I have to wait on a buddy for that unfortunately. Though I do have someone willing to lend me one I don't think they realize how long Ill have it...
              I do have some interior work I could be doing (grey carpet, black door cards, alcantara headliner, black rear panel, black seats, etc, but that won't get my car running.
              Excursion 7.3
              E30 LS1
              • CMartC
                CMartC
                CMart
                Welding my trans mount tomorrow, which means the motor and trans go in this weekend.
                In the mean time I started sorting through this mess.
                Anything special about the E30 brake lines? Will a normal brake line flare kit work?
                Excursion 7.3
                E30 LS1
                  37 degree or bubble flare is what they are I believe.
                    Bubble flares is what I was told by one of the old school techs. If you haven't done flares before good luck and hopefully they turn out. My suggestions would be to spend $$ on a good flare tool. I broke bits on doing lines on my old car and they ended up leaking too with a rental tool.
                      No you cannot use a standard brake line tool.
                      • CMartC
                        CMartC
                        CMart
                        4x100 16x7.5 AC Schnitzers... Picking them up this weekend.
                        Excursion 7.3
                        E30 LS1
                          Nice find!
                          • CMartC
                            CMartC
                            CMart
                            Thanks I think I got a pretty good deal on them.
                            Thinking about going gloss black, but feel bad painting these...
                            Excursion 7.3
                            E30 LS1
                              Silver is the way to go=)
                              • CMartC
                                CMartC
                                CMart
                                I think so too, but it will be the only thing not black or red on the car.
                                This also means I have to worry about suspension sooner that I was planning.
                                Excursion 7.3
                                E30 LS1
                                • CMartC
                                  CMartC
                                  CMart
                                  Exhaust manifolds fitted. Downpipes next.
                                  Any thoughts on dual exhaust E30s? I have an idea in mind for what I want to do, but am afraid it won't look right.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Excursion 7.3
                                    E30 LS1
                                      Those wheels look great on there. If you want to change the color of them, I would recommend plastidip since they look so immaculate=)
                                        Dual exhaust, lol.
                                        As long as the engine is a V or boxer then duals are acceptable.
                                          dual exhaust just doesnt look right on bmws of this vintage. its also not worth the extra cost or work over single: extra piping, two mufflers, extra cutting of the valance, more weight, etc etc.
                                          i'm going for a big single oval exhaust tip when I redo mine.
