  4. '88 E30
'88 E30
savebigmoney
    Gotta have that supermoto in at least one pic, huh? :P
      Haha. Yep. It's my room mates.
      It'll get torn down before the snow melts too
        Pics as of 20 minutes ago. It's crusty, but cleaning up alright
        Most of the accessories are off
          Haha. Yep. It's my room mates. It'll get torn down before the snow melts too
          Looks like the Triumph will need to go under the knife as well, unfortunately.
            Kaiser is getting more work done than anyone else. this truly is the Apocalypse
              About to go home and tear more crap apart
                Gonna need that oil pump nut soon.
                  Took more stuff off & worked off some of the crud.
                  And more junk came off
                  Had a metal water pump impeller. Neat
                  Cleaned more junks
                  That's about it, I still need to get the AC bracket off. But it's blocked 20901fcee01abcad5c7f2ccff5cb14cd.jpg
                  This is why I need four hands. Or. Friends. 868a99b90571e7c31da370c3d2ae21fd.jpg
                  Tomorrow I'll take more crap off and post more blurry pics
                    Just going earl mode for now until I pick up an impact and or grow a pair and pop the head offa2cda3c11cd6e676da4c8546c0a4f54d.jpg6725581011a8ca1b3dc67eb4f8029497.jpg17b0837c795396d5cec40c29147dd33f.jpg
                    So far I've just been using a wire brush and some simple green. I'll hit it with some powa toolz eventually
                      poor mans impact: put ratchet on bolt. hit handle with big mallet.
                      always worked for me.
                        I don't want to just keep turning the crank though haha
                          I couldn't get my crank pulley bolt off at all. Kyle Kompas had to take it to his shop to heat it and zip it off with a pretty large impact haha
                            I would get the flywheel lock pin. You can use it with the stock FW but not the one you're going to buy from me. Or use a screw driver. Or use a 2x4 and wedge it in the crank shaft.
                            Be sure to get a new bolt as these are strech bolts and only are good for one time only.
                              Good to know john.
                              There is no flywheel on the motor currently
                                Saw that.
                                  Won't fit with the engine on the stand either=/
                                    No sir. Looks like 2x4 and impact will be the way it has to come off 😕
                                      I've taken apart 3 M42s without an impact or anything to lock the crank/flywheel. The hammer/mallet only puts force on the the bolt for a fraction of a second. The inertia of the crank is enough to keep it from turning (much). I'm not saying it's the best way to do it, or even a good way, but it works.
                                        Mine was done with just head and an impact. You don't want to risk cracking that block with the 2x4 method
                                          I won't do the 2x4 thing, that would be ultimate mega last resort of all proportions. I'm just gonna hit the shit out of it with a hammer until something breaks or breaks loose
