  4. '88 E30
'88 E30
savebigmoney
    Gonna get a different clutch/flywheel setup eventually (possibly flywheel from Drleadballs). Everything it pretty much of the engine now. No PS. No AC (just the AC bracket yet) no tensioners no intake no exhaust, etc.
    I'm getting pretty familiar with the wire brush 6053d62189ca19c16d5d4c89d66b3abb.jpg
    I really hope that's the only "surprise" I find on this thing
      DrLeadFoot said:
      Mid engine Moto-x?
      Good god man, you need my flywheel!?
      lol - most likely, thing looks like it was used to cut concrete
        http://www.turnermotorsport.com/p-3794-e36-m3-clutch-flywheel-upgrade-package-for-e36-323325328.aspx
          I'll make the price right.
            The ECS magnetic drain plugs are nice if people actually follow the torque spec. People usually put pan plugs in at NGA and that is why people were snapping them=/
              Gotta have that supermoto in at least one pic, huh? :P
                Haha. Yep. It's my room mates.
                It'll get torn down before the snow melts too
                  Pics as of 20 minutes ago. It's crusty, but cleaning up alright
                  Most of the accessories are off
                    Haha. Yep. It's my room mates. It'll get torn down before the snow melts too
                    Looks like the Triumph will need to go under the knife as well, unfortunately.
                      Kaiser is getting more work done than anyone else. this truly is the Apocalypse
                        About to go home and tear more crap apart
                          Gonna need that oil pump nut soon.
                            Took more stuff off & worked off some of the crud.
                            And more junk came off
                            Had a metal water pump impeller. Neat
                            Cleaned more junks
                            That's about it, I still need to get the AC bracket off. But it's blocked 20901fcee01abcad5c7f2ccff5cb14cd.jpg
                            This is why I need four hands. Or. Friends. 868a99b90571e7c31da370c3d2ae21fd.jpg
                            Tomorrow I'll take more crap off and post more blurry pics
                              Just going earl mode for now until I pick up an impact and or grow a pair and pop the head offa2cda3c11cd6e676da4c8546c0a4f54d.jpg6725581011a8ca1b3dc67eb4f8029497.jpg17b0837c795396d5cec40c29147dd33f.jpg
                              So far I've just been using a wire brush and some simple green. I'll hit it with some powa toolz eventually
                                poor mans impact: put ratchet on bolt. hit handle with big mallet.
                                always worked for me.
                                  I don't want to just keep turning the crank though haha
                                    I couldn't get my crank pulley bolt off at all. Kyle Kompas had to take it to his shop to heat it and zip it off with a pretty large impact haha
                                      I would get the flywheel lock pin. You can use it with the stock FW but not the one you're going to buy from me. Or use a screw driver. Or use a 2x4 and wedge it in the crank shaft.
                                      Be sure to get a new bolt as these are strech bolts and only are good for one time only.
                                        Good to know john.
                                        There is no flywheel on the motor currently
                                          Saw that.
