pistonse30
    Rowleym said:
    Ordered a bunch of stuff yesteday to get the trans maintenance up to date.  5th and reverse gear drivers (?), output shaft seal, shifter linkage seal, foam selector link thing, a set of drift tools.
    Here goes nothing!
    Any idea how much this was and where you got it from? I'm about to go down the same road.
    What are you looking for? I started a thread about the zf trans with a bunch of links.
    • CMartC
      CMartC
      CMart
      I love this build.
      Can't wait to get mine running and check out your tail lights.
      Excursion 7.3
      E30 LS1
        CMart said:
        I love this build.
        Thanks!
        Waiting on you!! Let's run 'em.
        • CMartC
          CMartC
          CMart
          My old timeline was wait until spring then start the build again, but I've actually been making good progress in the cold. New goal is to have everything buttoned up by spring and get it on the road as soon as the salt is gone.
          I've been spending too much time parting the E39, but once its gone I will be able to work on the E30 much more efficiently with the extra room.
          DrLeadFoot said:
          Thanks!
          Excursion 7.3
          E30 LS1
          • CMartC
            CMartC
            CMart
            Also what are you putting down?
            Excursion 7.3
            E30 LS1
              Last time I dyno'd it it was 442whp at 13psi.
              I'm now at 18psi with a slipping clutch... I just want to break the 500whp mark.
              I also have to pop in a new t3 turbo gasket. Mine currently is venting to atmosphere.
              • CMartC
                CMartC
                CMart
                Definitely viewing tail lights.
                Excursion 7.3
                E30 LS1
                  Got around to doing a little work on the car while in my basement.
                  Popped of the foamy thing.
                  It was all oil mush.
                  Gently pry a bit.
                  Off she comes!
                  New vs. Old
                  Oiled up the gasket, took a 15mm socket and tapped it home.
                  After cleaning up the tar-ish residue on the rod popped on the new foamy thing on with the dowel held in by the snap ring.
                  Waiting for more small parts from pelican. They're getting a call tomorrow...
                    Meanwhile while still waiting for parts from pelican this happened.
                    Condor Speed Shop's 2015 calendar!
                      Congrats=)
                        Stopped out by Dan THE Exhaust Man's place.
                        The wing is in the works!!
                        6a6bafadadf56a166943e36124a33378.jpg8c60fe6e5032fb890fc4d0c8242f691f.jpge68e39b8703bdfe1fbd4e315f5eace9a.jpg8aac5e2d767e7a659aa08b449ef353a5.jpg
                          Got the driveshaft and trans out.
                          Now let's go Marquette Warriors!!!
                            What are you selling the g260 for?
                            I read that as Now let's go Megasquirt!!!
                              $175 with the short shifter and linkage.
                                Got the clutch and flywheel out. Gotta love zipties!
                                66c39628d0864011e43a490b08373b12.jpg507e3cddbdb748efc018dec55e67eeb5.jpgd327f7f7983d3571fd0dfa77e9b54b60.jpgc2fc8810fa05a96638eb169b2824f0b0.jpg1e04fe356e99a670d8488ed089068ccd.jpg
                                A little slipping going on there. The pressure plate is a Sachs, clutch is a Southbend stage 4 and JB racing flywheel. Couldn't handle around 400ft/lbs.
                                  stock pressure plate or 618 Pp? Just the southbend stage 4 disc?
                                    Not sure. Bought the whole thing off of a guy on bimmerforums. I think it's just the disc.
                                      What are you selling the g260 for? I read that as Now let's go Megasquirt!!!
                                      $75 just for the trans.
                                        Finally!
                                        Trans time.
                                          Had to wait on your Duck + VW Beetle sticker, eh?
