pistonse30
    Rowleym said:
    manual e36 m3 with the 4 bolt in the rear.  or 87-88 325E large guibo. 328I manual as well
    Corrected because I spread wrong information( I HATE THAT)
      Got a trans, driveshaft and shifter linkage off a 98 M3 for $240 from Don's.
      Just need an e30 trans mount/brace thing!! Anyone have one collecting dust with one?
        I bet just about all of us do!
        Wait don't you? Ahh you modified  yours...
          Ship me one!!
            Got some goods! They need some TLC.
              DrLeadFoot said:
              Trying to get a new nickname stat!  Clutch Sniffer is the worst!!!
              Fixt
                Ordered a bunch of stuff yesteday to get the trans maintenance up to date.  5th and reverse gear drivers (?), output shaft seal, shifter linkage seal, foam selector link thing, a set of drift tools.
                Here goes nothing!
                  Here goes nothing!
                  Any idea how much this was and where you got it from? I'm about to go down the same road.
                    Here goes nothing!
                    What are you looking for? I started a thread about the zf trans with a bunch of links.
                    • CMartC
                      CMartC
                      CMart
                      I love this build.
                      Can't wait to get mine running and check out your tail lights.
                      Excursion 7.3
                      E30 LS1
                        CMart said:
                        I love this build.
                        Thanks!
                        Waiting on you!! Let's run 'em.
                        • CMartC
                          CMartC
                          CMart
                          My old timeline was wait until spring then start the build again, but I've actually been making good progress in the cold. New goal is to have everything buttoned up by spring and get it on the road as soon as the salt is gone.
                          I've been spending too much time parting the E39, but once its gone I will be able to work on the E30 much more efficiently with the extra room.
                          DrLeadFoot said:
                          Thanks!
                          Excursion 7.3
                          E30 LS1
                          • CMartC
                            CMartC
                            CMart
                            Also what are you putting down?
                            Excursion 7.3
                            E30 LS1
                              Last time I dyno'd it it was 442whp at 13psi.
                              I'm now at 18psi with a slipping clutch... I just want to break the 500whp mark.
                              I also have to pop in a new t3 turbo gasket. Mine currently is venting to atmosphere.
                              • CMartC
                                CMartC
                                CMart
                                Definitely viewing tail lights.
                                Excursion 7.3
                                E30 LS1
                                  Got around to doing a little work on the car while in my basement.
                                  Popped of the foamy thing.
                                  It was all oil mush.
                                  Gently pry a bit.
                                  Off she comes!
                                  New vs. Old
                                  Oiled up the gasket, took a 15mm socket and tapped it home.
                                  After cleaning up the tar-ish residue on the rod popped on the new foamy thing on with the dowel held in by the snap ring.
                                  Waiting for more small parts from pelican. They're getting a call tomorrow...
                                    Meanwhile while still waiting for parts from pelican this happened.
                                    Condor Speed Shop's 2015 calendar!
                                      Congrats=)
                                        Stopped out by Dan THE Exhaust Man's place.
                                        The wing is in the works!!
                                        6a6bafadadf56a166943e36124a33378.jpg8c60fe6e5032fb890fc4d0c8242f691f.jpge68e39b8703bdfe1fbd4e315f5eace9a.jpg8aac5e2d767e7a659aa08b449ef353a5.jpg
                                          Got the driveshaft and trans out.
                                          Now let's go Marquette Warriors!!!
