pistonse30
    remove the timing chain so that the pistons will be slowed down and it will reduce ring wear while priming.
      In all seriousness, I usually prime an engine by removing the fuel pump fuse and pulling the spark plugs, no compression = no load on the bearings and it spins over much faster.  It still takes longer than you think it would to build pressure in a new engine but yours wasn't fully disassembled.
        Just bite down on a pillow and crank it already.
          Knocking things off the list!
          Subframe all torqued down.
          Steering rack and skid plate on.
          On the ground!!!! #beentoolong
          Getting close!!!
            You need to paint your control arms!
              I know...I know...
              I just want to drive!
                Getting closer!
                Need to get a new brass crush ring for the boost gauge. The original hose was crimped at the nut. Then I'll be good to go.
                The crank torque tool should be arriving today.
                  Rear calipers and new Hawk HPS pads on. Ready for the road!
                  Got my Jesus bolt torqued down.
                  New updated list:
                  -Charge battery a little
                  -Install radiator
                  -Add fluids
                  -Prime oil system
                  -Fire it up!
                    Almost there.  I have HPS pads on our Maxima and very happy with them, excellent feeling street pad and they seem to last forever, I think they are around 40k and still over half of the material left.  Not sure if it matters much but they are on Brembo slotted rotors as well.
                      Doing some more wedding planning today which means wrenching on the bimmer and sending emails with the fiancee!
                        I hope this is your get away car and you do a nasty burn out after you tie the knot haha! #h3gon3
                          On the road again!!!!!!!
                            Video of a burnout or bust!
                              bassboy said he would do a burnout first, lets wait for him to post his burnout video.
                                BURNOUT!!!!!!!!!!!!!!!
                                  Haha.
                                  She is running great! Feels so good to be back behind the wheel.
                                  I'll get it cleaned up tomorrow and snap some pictures.
                                    Need to do this:  http://e30.bmwdiy.info/indy-fogs/
                                    And wire up my city lights with the dims.
                                      Installed my e30m3 wiring cover.
                                      Other random pics:
                                      Curiosity of Billy:
                                      Mileage pic:
                                      Needs this:
                                        Beep Beep!!
                                          Bassboy3313 said:
                                          Beep Beep!!
                                          you've opened a can of worms.
                                          The "Meep Meep!!" people and the "Beep Beep!!" people are going to slaughter eachother now.
