    ...looks like it
      Is it nessesary? Hope not cuz the pan is on and torqued. ........
        Not necessary, MEGASQUIRT is necessary
        You are mostly just losing a little bit of power to parasitic losses . Without megasquirt you are losing out on lots of power
        Get some.
          Might do this before getting mega.
          https://www.google.com/url?sa=t&source=web&cd=3&ved=0CCUQFjAC&url=http%3A%2F%2Fwww.r3vlimited.com%2Fboard%2Fshowthread.php%3Ft%3D119358&rct=j&q=irsc4%20rear%20suspension%20e30%20bmw&ei=XOcYVN2xLYvKaIqqgMAC&usg=AFQjCNG1rcp0bbqGJIl3zo3kKTjqMYNhgg&bvm=bv.75558745,d.d2s
            Thats full on dragster mode
            Needs more broken looking launches with stock semi-trailing arm rear suspension
              1608057pics-max-7858-259272-bmw-e30-drag
                Get some wheels with a reasonable offset so you can run some real tires (your current tires are silly being 225 or 235) and go from there.
                  I'm running 215's haha.
                  The oil pan is on! Might do some work tonight.
                  Update on the to do list:
                  - Install new motor mount bolts to the passenger side. Drivers is done. DONE
                  - Torque down transmission. DONE
                  - Prime and paint the frame where and front subframe connect. DONE
                  - Install subframe. DONE
                  - Install steering rack and skid plate. DONE
                  - Intake manifold, throttle body and hook up charge pipes. DONE
                  - Radiator and fluid.
                  - Add oil.
                  - Turn motor over by hand 20 some times to pump the oil through the ant farm.
                  - Install and bleed rear calipers. DONE
                  - DRIVE!!
                    Your 215's make me laugh!
                    Also, you can use the starter to prime the engine, just pull the fuel pump fuse.
                      remove the timing chain so that the pistons will be slowed down and it will reduce ring wear while priming.
                        In all seriousness, I usually prime an engine by removing the fuel pump fuse and pulling the spark plugs, no compression = no load on the bearings and it spins over much faster.  It still takes longer than you think it would to build pressure in a new engine but yours wasn't fully disassembled.
                          Just bite down on a pillow and crank it already.
                            Knocking things off the list!
                            Subframe all torqued down.
                            Steering rack and skid plate on.
                            On the ground!!!! #beentoolong
                            Getting close!!!
                              You need to paint your control arms!
                                I know...I know...
                                I just want to drive!
                                  Getting closer!
                                  Need to get a new brass crush ring for the boost gauge. The original hose was crimped at the nut. Then I'll be good to go.
                                  The crank torque tool should be arriving today.
                                    Rear calipers and new Hawk HPS pads on. Ready for the road!
                                    Got my Jesus bolt torqued down.
                                    New updated list:
                                    -Charge battery a little
                                    -Install radiator
                                    -Add fluids
                                    -Prime oil system
                                    -Fire it up!
                                      Almost there.  I have HPS pads on our Maxima and very happy with them, excellent feeling street pad and they seem to last forever, I think they are around 40k and still over half of the material left.  Not sure if it matters much but they are on Brembo slotted rotors as well.
                                        Doing some more wedding planning today which means wrenching on the bimmer and sending emails with the fiancee!
                                          I hope this is your get away car and you do a nasty burn out after you tie the knot haha! #h3gon3
