pistonse30
    I have bought Plastigage from Napa before, you have to ask for it, it was in a pretty dusty box at my store lol.
    • mkoeppM
      mkoeppM
      mkoepp
      Bassboy3313 said:
      Where did you get the plasti gauge stuff from? I will need to do this when I start reassembling my spare block.
      I know NAPA has them. Any parts house should have them.
        All are torqued, three are in the pic.
          Pegasus Racing has the plastic gauge.
          • JeffJ
            JeffJ
            Jeff
            Nice to see people actually checking specs when there building motors.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              I'm just terrified that I'm going to blow this up so I need to do it the right way.
                Plastidipping the crank was an odd choice.
                Racekor.
                  #tothelastdetail
                  • JeffJ
                    JeffJ
                    Jeff
                    People usually don't clean journal bearing seats or install the bearings right 90% of builds gone wrong. Spun bearings are bad news
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      I think I did it right. Tried to keep everything as clean as possible. Rubber gloves and brake clean were flying everywhere!
                        What is all the white stuff that you have on the main bearings and caps? Assembly lube of sorts?
                        Are you replacing the crank sprocket? You had mentioned that it was rounded.
                        Looking good!
                          Assembly Lube ;)
                          My project of the weekend is to get the new sprocket on.
                            These two inverted torx bolts that secure the lower cover on were finger loose. No wonder I was leaking oil.
                            #loctiteeverything
                              Another nice find by the doctor!
                                Jesus bolt out.
                                Stretched as I thought. If you didn't read it earlier the bolt was easily loosened by a big pair of channel grips.
                                  Any advise to get the middle torx bolt on the timing case cover loose without removing the cams?
                                    You might have to remove the short chain and tensioner but not the cams.  Try a 1/4" drive 12pt socket and swivel.
                                      Still trying to find time and motivation to get in the garage.
                                      I was thinking about not using the metal gasket on the front cover and just going for the Ford black atv sealant.  In order for Kummrow to stop the leaking I had to ask them to ATV seal all gaskets.
                                      I will be ordering new exhaust vanos sprocket bolts just in case the old ones are stretched out like every other bolt has been so far.
                                      That should be it for parts then I just have to get my ass in gear!!
                                        What is your crankcase vented to?  I'm just curious because I have never had leaking problems like this.  If your crankcase gets pressurized though it will leak everywhere.
                                          I have it on vacuum via the exhaust.
                                          Have you turbo'd one before?  I guess they leak pretty bad from the crank case pressure.
