  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
do it myself
192 Posts 14 Posters 3.4k Views 3 Watching
    bfinley
    Might be saving a bunch of cash and getting the clutch and fly off the Kamotors e30
    Got the shifter linkage
    Flares are ordered
    Got a second lead on fenders in good shape
    So I'm using mine to test the paint scheme
    Dtm fiberwerks Motorsport front bumper and factory rear vent windows are on there way shortly
    Now I need to drop the rear sub, get the drive shaft out
    Fab motor mounts
    Fix brakes
    Paint
    Reassemble
    M20 burnouts !
    • RamRod E28R
      RamRod E28R
      RamRod E28
      Its so easy when you say it isnt it?!
      1988 BMW 528e - Need parts?
      1996 Mazda Miata (SOLD!!!)
      1996 BMW 325i (Donor car)
        bfinley
        I just have to keep saying it and crossing things off the list...
          In4m20burnouts
            bfinley
            Almost done with the KBS on the front end, I've started priming at sanding the fenders and trunk lid. Need to get the hood down, kbs, then scuff it and spray the first layer of primer
              Awesome, I should stop by after work this week.  When are you usually at the shop?
                Keep it up man! Looking good!
                  bfinley
                  Got the first layer of green on the fenders only to run out, no one in town currently has the dupli-color self etching OD flat primer that I'm using.
                  I'm going to check with napa tomorrow about custom mixed aerosol cans....
                  Since I didn't want to go home with no power I went back to the shop and cut my riveted aluminum panels to cover the gaping holes in the fenders
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    bfinley said:
                    eqa3avuj.jpg Got the first layer of green on the
                    Is that bud light lime I see???
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      DO IT!!!
                        bfinley
                        The whole exterior of the car is in primer
                        Fenders and trunk kid are green!
                          bfinley
                          The Kamotors e30 fender flares showed up so I quick mocked them up.
                          They will need some trimming to fit.
                          Shot the first layer of matte clear on the trunk and fenders last night along with a rubberized underliner on the rockers.
                          Wet sanding the shell starts tonight and then first round of OD green !
                            What are your thoughts for wiring?  Mike said the wiring was a disaster, possibly caused by him lol.  I wonder about using a small aftermarket fusebox to do the remaining body wiring.  I imagine it will be very minimal or what are your thoughts?
                            • RamRod E28R
                              RamRod E28R
                              RamRod E28
                              The wiring was a cluster f*** so many splices that went to god knows where!
                                bfinley
                                Well we know where they all go now ...
                                  bfinley
                                  I haven't done much research yet, bug I've been thinking about it. All I will need to control is headlights, tail lights/turn signals, and whatever power my custom gauges need. Which for the time being will be a tach and a garmin gps ...
                                    Just do a new chassis harness from painless, or like us with the "ezwiring" kit. SOOO easy, and cheap. Never screw with 30+ year old wiring.
                                      I know an electrician that could wire it up for you...  What is your timeline for wiring?  Have you checked out gauges from innovate?  They have some combo gauges, oil temp/pres, water temp/batt voltage, and some nice widebands.  For a pretty decent price too.  I will be using these in my e36 when it is coming back together.
                                        bfinley
                                        Could happen simultaneously with the motor which should be starting next week after I finish the body
                                          OK, I could put in some time on Mondays.
