  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
do it myself
192 Posts 14 Posters 3.4k Views 3 Watching
    bfinley
    Almost done with the KBS on the front end, I've started priming at sanding the fenders and trunk lid. Need to get the hood down, kbs, then scuff it and spray the first layer of primer
      Awesome, I should stop by after work this week.  When are you usually at the shop?
        Keep it up man! Looking good!
          bfinley
          Got the first layer of green on the fenders only to run out, no one in town currently has the dupli-color self etching OD flat primer that I'm using.
          I'm going to check with napa tomorrow about custom mixed aerosol cans....
          Since I didn't want to go home with no power I went back to the shop and cut my riveted aluminum panels to cover the gaping holes in the fenders
          • RamRod E28R
            RamRod E28R
            RamRod E28
            bfinley said:
            eqa3avuj.jpg Got the first layer of green on the
            Is that bud light lime I see???
            1988 BMW 528e - Need parts?
            1996 Mazda Miata (SOLD!!!)
            1996 BMW 325i (Donor car)
            • RamRod E28R
              RamRod E28R
              RamRod E28
              DO IT!!!
                bfinley
                The whole exterior of the car is in primer
                Fenders and trunk kid are green!
                  bfinley
                  The Kamotors e30 fender flares showed up so I quick mocked them up.
                  They will need some trimming to fit.
                  Shot the first layer of matte clear on the trunk and fenders last night along with a rubberized underliner on the rockers.
                  Wet sanding the shell starts tonight and then first round of OD green !
                    What are your thoughts for wiring?  Mike said the wiring was a disaster, possibly caused by him lol.  I wonder about using a small aftermarket fusebox to do the remaining body wiring.  I imagine it will be very minimal or what are your thoughts?
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      The wiring was a cluster f*** so many splices that went to god knows where!
                        bfinley
                        Well we know where they all go now ...
                          bfinley
                          I haven't done much research yet, bug I've been thinking about it. All I will need to control is headlights, tail lights/turn signals, and whatever power my custom gauges need. Which for the time being will be a tach and a garmin gps ...
                            Just do a new chassis harness from painless, or like us with the "ezwiring" kit. SOOO easy, and cheap. Never screw with 30+ year old wiring.
                              I know an electrician that could wire it up for you...  What is your timeline for wiring?  Have you checked out gauges from innovate?  They have some combo gauges, oil temp/pres, water temp/batt voltage, and some nice widebands.  For a pretty decent price too.  I will be using these in my e36 when it is coming back together.
                                bfinley
                                Could happen simultaneously with the motor which should be starting next week after I finish the body
                                  OK, I could put in some time on Mondays.
                                    bfinley
                                    Awesome ! I'll look into those gauges tonight
                                      bfinley
                                      Welded in patch panels over the rear assembly holes. Not my prettiest welds but it's solid. Once I bedline the interior you won't see them.
                                      Have to pull the fuel lines before I cut the front floors
                                        Looks good man!
                                          bfinley
                                          Things are starting to line up. Single mass flywheel ordered, an 885 head had been dibsed. lots of work planned for this weekend. The fuel tank is on it's way out as is the front subframe. I'll get that cleaned up and work on fabricating motor mounts. Once the fuel system is stripped I can finish patching the floors as well. Now I just need a clutch.
