  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
192 Posts 14 Posters 0 Views 1 Watching
    lots of dust up in there!
    Are you finished with the metal cutting/welding patches?
      bfinley
      Well I went to the Motorwerks BMW in Bloomington MN on Saturday since I am at my parents for the weekend.
      They want 538 dollars for everything in the specific exploded diagram, I politely thanked them for their time and walked out with an itemized list and the memory of why I don't work for a dealership anymore.
      After doing some more digging about my specific trans I found that it is a "late" model gt 260 which can accept both the plate and beam style of shifter...
      So that helps and I'll be holding out for a used part instead of dropping a ridiculous amount for NEW
      Which means I can look at buying the clutch and flywheel as well.
      Shooting for an installable motor by the end of the month.
      Here's the website that helped me sort out which version of the 260 I've got
      http://www.unofficialbmw.com/phpBB/viewtopic.php?t=33173
      AND - dohcdoh on bimmerforums.com just sold me a complete linkage for 45 dollars shipped... that is a lot better than 500!
        bfinley
        Havent started yet... I'll admit that cutting the floor out scares me a bit and I've been fixated on getting the pait stripped so I can deep clean the shop and be done with that.
          Glad you found one, I got one minus the shifter itself for 35 shipped.  I just used my old e36 shifter for the e30.  What are you thinking for the flywheel clutch setup?
            bfinley
            Yeah someone said I could reuse the e21 shifter as well, I figured what the heck and got the whole unit so I don't have to mess around with it.
            I'll get a short shifter eventually as well.
            Clutch and flywheel I'm just going to buy new and bite that bullet but as long as both pieces are for the same car I can use a clutch and fly wheel from any model e30 I like, so lightweight single mass kit it is.
            spending 700 bucks on a kit doesn't sound so bad when you're not spending 500 dollars on a shifter either
              What kits in particular are you looking at?  I think my UUC is great at 11.5 lbs (flywheel is actually 8.5 but the larger clutch/PP is 3lbs more than stock) but very expensive.  After more research I think the are made by Fidanza, I am not convinced that the Ebay ones are different at all.  You may be able to tell by what clutch parts are used in the kit.  Mine uses an e34 m5 oem clutch, PP, and throwout bearing.
                bfinley
                The UUC from BAV auto with the oem M5 clutch for 900 bucks?
                  Ok, Watch their site directly, they do nice promos almost every weekend, until midnight it is 10% off and free shipping.  The price on their site is $974.  They frequently do 15% off so I would hold out for that, Price has probably gone up from 3 years ago but I think I paid 750ish.
                    bfinley
                    Might be saving a bunch of cash and getting the clutch and fly off the Kamotors e30
                      bfinley
                      Got the shifter linkage
                      Flares are ordered
                      Got a second lead on fenders in good shape
                      So I'm using mine to test the paint scheme
                      Dtm fiberwerks Motorsport front bumper and factory rear vent windows are on there way shortly
                      Now I need to drop the rear sub, get the drive shaft out
                      Fab motor mounts
                      Fix brakes
                      Paint
                      Reassemble
                      M20 burnouts !
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        Its so easy when you say it isnt it?!
                        1988 BMW 528e - Need parts?
                        1996 Mazda Miata (SOLD!!!)
                        1996 BMW 325i (Donor car)
                          bfinley
                          I just have to keep saying it and crossing things off the list...
                            In4m20burnouts
                              bfinley
                              Almost done with the KBS on the front end, I've started priming at sanding the fenders and trunk lid. Need to get the hood down, kbs, then scuff it and spray the first layer of primer
                                Awesome, I should stop by after work this week.  When are you usually at the shop?
                                  Keep it up man! Looking good!
                                    bfinley
                                    Got the first layer of green on the fenders only to run out, no one in town currently has the dupli-color self etching OD flat primer that I'm using.
                                    I'm going to check with napa tomorrow about custom mixed aerosol cans....
                                    Since I didn't want to go home with no power I went back to the shop and cut my riveted aluminum panels to cover the gaping holes in the fenders
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      bfinley said:
                                      eqa3avuj.jpg Got the first layer of green on the
                                      Is that bud light lime I see???
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        DO IT!!!
                                          bfinley
                                          The whole exterior of the car is in primer
                                          Fenders and trunk kid are green!
