1978 e21 m20 turbo swap, AKA What did I get myself into
Glad you found one, I got one minus the shifter itself for 35 shipped. I just used my old e36 shifter for the e30. What are you thinking for the flywheel clutch setup?
Yeah someone said I could reuse the e21 shifter as well, I figured what the heck and got the whole unit so I don't have to mess around with it.
I'll get a short shifter eventually as well.
Clutch and flywheel I'm just going to buy new and bite that bullet but as long as both pieces are for the same car I can use a clutch and fly wheel from any model e30 I like, so lightweight single mass kit it is.
spending 700 bucks on a kit doesn't sound so bad when you're not spending 500 dollars on a shifter either
What kits in particular are you looking at? I think my UUC is great at 11.5 lbs (flywheel is actually 8.5 but the larger clutch/PP is 3lbs more than stock) but very expensive. After more research I think the are made by Fidanza, I am not convinced that the Ebay ones are different at all. You may be able to tell by what clutch parts are used in the kit. Mine uses an e34 m5 oem clutch, PP, and throwout bearing.
Ok, Watch their site directly, they do nice promos almost every weekend, until midnight it is 10% off and free shipping. The price on their site is $974. They frequently do 15% off so I would hold out for that, Price has probably gone up from 3 years ago but I think I paid 750ish.
Might be saving a bunch of cash and getting the clutch and fly off the Kamotors e30
Got the shifter linkage
Flares are ordered
Got a second lead on fenders in good shape
So I'm using mine to test the paint scheme
Dtm fiberwerks Motorsport front bumper and factory rear vent windows are on there way shortly
Now I need to drop the rear sub, get the drive shaft out
Fab motor mounts
Fix brakes
Paint
Reassemble
M20 burnouts !
Its so easy when you say it isnt it?!
In4m20burnouts
Keep it up man! Looking good!
Got the first layer of green on the fenders only to run out, no one in town currently has the dupli-color self etching OD flat primer that I'm using.
I'm going to check with napa tomorrow about custom mixed aerosol cans....
Since I didn't want to go home with no power I went back to the shop and cut my riveted aluminum panels to cover the gaping holes in the fenders
Got the first layer of green on theIs that bud light lime I see???
DO IT!!!
The Kamotors e30 fender flares showed up so I quick mocked them up.
They will need some trimming to fit.
Shot the first layer of matte clear on the trunk and fenders last night along with a rubberized underliner on the rockers.
Wet sanding the shell starts tonight and then first round of OD green !
The wiring was a cluster f*** so many splices that went to god knows where!
