  4. E21 project thread
E21 project thread
    Been working on getting the charge piping cut/ground/welded since realizing that the e30 ellipsoids with HIDs I am running interfere with the SMIC placement. For now I will run it without an IC like I have been in the past. Until I figure something else out that is. Been a slow process which really makes me wish I had a welder and the skills to do it myself. Oh well.
      Got the welded up charge piping back the other day.
      The pieces that were made back in the 80s turned out to be mild steel instead of aluminum, so I had to get a coat of paint or powdercoat on them to prevent rusting. So I opted to paint all the piping in cast iron gray color.
      I love the color and it goes with the old school theme of the car. Looks brownish gray in the sun but kind of army green in the shade. I still dig! I got it all mounted up and snugged down. Along with the IAC to intake hose as well.
      Just need to hook a few more things up and fill with fluids and I should he able to try starting it. Soon!
        im so giddy
          Got my new +0.50mm pistons in the mail today for the 2.0 block rebuild side project.
          • andyhundleyA
            andyhundleyA
            andyhundley
            I'm excited to ride in this!
            • RamRod E28R
              RamRod E28R
              RamRod E28
              I want that charge pipe color for my engine bay that looks so good!
              1988 BMW 528e - Need parts?
              1996 Mazda Miata (SOLD!!!)
              1996 BMW 325i (Donor car)
                Duplicolor high temp Cast Iron Gray.
                Great color
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  That's the color of my engine bay.
                    It's a great color!
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      Yep! PM me and we can setup a royalty payment schedule.
                      All kidding aside, It looks good on those charge pipes. Bring this thing to work so I can sneak a peek in the parking lot!
                        Thanks to kyle (kyletime666) for doing the machine work on my side 2.0L project, I got the cleaned and polished crank back today.
                        Did a few more things to the car today, but hopefully tomorrow I can crank a lot more of the piddly stuff out.
                          Got quite a bit of the piddly stuff done today. Ran fpr vac to fitting on manifold, filled with coolant, changed oil, secured return fuel hose to hard line, got a large vac cap for a spot on throttle body, tightened oil cooler lines and turbo oil feed line and tightened alternator down.
                          I also figured out a spot to mount my custom catch can, hidden behind the brake booster. I took the spare piece of aluminum strip I had and bent up a bracket for it. Drilled some mounting holes, powdercoated it and boom, done! Just need to run the hoses from valve cover to intake.
                            Making brackets is more gratifying than it should be. I expect to be plenty busy later this week helping you and milwaukeeandy , the thought is quite exciting
                              How's the triple?
                                How's the triple?
                                Lovely as usual! If only it would stop freakin raining. I see you've been getting your supermoto fix lately too, eh?
                                  Lightened and surfaced flywheel!
                                    So I got everything connected and done on the car and it is time to get it running and driving. She cranks very nicely, but of course doesnt want to fire. I figure it is something with the Megasquirt wiring either on the car or in the MS ecu itself. Snap and I are currently researching and working on these bugs. Hopefully will have a nice update at some point here.
                                      Yay for updates.
                                      Edit: is the issue that burnt out capacitor that snap sent me a pic of?
                                        no
                                        i have no idea what im doing.
                                          I wish I lived closer, I would come check it out.
