  4. Reducing turbo lag: What should my next step be?
41 Posts 13 Posters 833 Views 1 Watching
    Thanks for the input Rowley
    I added some timing advance down low and will be doing the "Dodge Garage" modification to my blowoff valve because I know it is bleeding off some pressure under WOT and shall see how things improve there.
    • TCDT
      TCDT
      TCD
      If you take a data driven approach to building/tuning your car you will be much better off.  Guessing at solutions doesn't work.  You have fantastic data logging capabilities.  You need to use them.
        Anything specific he should datalog?
          log all the things
          • NarcosisN
            NarcosisN
            Narcosis
            Everything.  The more data available the better.   Snap - which datalogging capabilities is TCD speaking of?  How is your car setup today?
            FWIW, when I log my car (jb4 equipped) I get all possible data available via the OBD2 port.  That way I can display anything/everything I want when addressing a possible issue with the tune/car/setup/etc.
              Megasquirt
              Everything can be logged.  everything and more
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                E30 anti-lag coming soon to a quiet suburb near you.
                I've watched this video 20+ times and I still giggle like a little school girl
                  I like the burnt portion of the strap
                  • frcefedF
                    frcefedF
                    frcefed
                    I have the same dimensions on my Garrett t3t4 with ball bearings (and a warranty, thanks todd:)) and I have quite a bit of lag too, boost builds around 2600 and I hit 20psi around 4300rpms. I've been thinking about going the adjustable cam gear route.
                      Good to know. I cant fathom 20psi
                      • frcefedF
                        frcefedF
                        frcefed
                        Well its only supposed to be 15psi but my boost controller sucks and anything over 13psi and my clutch slips anyway. Ha
                          Haha! Mine does as well so its somewhat humorous that part throttle is faster than full throttle sometimes. Id really like to check it out sometime though
                          • frcefedF
                            frcefedF
                            frcefed
                            'Part throttle is faster than full throttle' I know! I always thought there was something wrong with my turbo or something. Haha
                            • frcefedF
                              frcefedF
                              frcefed
                              I ordered a performance clutch from UUC but I'm still waiting for it to come in.
                              • NarcosisN
                                NarcosisN
                                Narcosis
                                The only thing that comes to mind is "why?"...
                                  So there is no turbo lag
                                    Because Rocketship!
                                      Should have bought a turbo without such outdated design hehe. Gotta love Garrett. Let's bandaid our bad design with a ball bearing cartridge that can't be rebuilt!
                                        I have a friend named Garrett.
                                        You be nice.
                                          Here is the latest  in my quest to spool sooner.
                                          I modified the blowoff valve because it sounded as if it was opening a bit prematurely, that doesnt seem to be the case but it does seem to be holding more after 8psi now so that's a win. Threshold1zps96ab8a28.jpg
