<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Reducing turbo lag: What should my next step be?]]></title><description><![CDATA[<p dir="auto"><strong>Things that do not get old:</strong>  Rear end just a tidbit sideways, tires lightly spinning, while still gripping enough to accelerate, all the way through 2nd gear.</p>
<p dir="auto"><strong>Things that keep me awake at night:</strong> A non-turbo M20 would be a lot more fun around a racetrack than this due to turbo lag. And this matters because it is my intention to do the occasional track day.</p>
<p dir="auto">Currently I am running a T3/T4E  .63 A/R hot side .60 A/R cold side  journal bearing CX Racing turbo.<br />
I sized it for 350hp at 15psi.  I am currently at 12psi and am quite certain I am a little over the 300hp mark right now and extremely pleased with the performance on the top end.</p>
<p dir="auto">under full load, boost begins at 2800 rpm and 12psi is attained from 5000 rpm and up.</p>
<p dir="auto">The power comes on just a bit too suddenly after a bit of lag.  I am very new to the forced induction game so I do not know what to expect from my own car, but I would like to think that it doesn't have too much lag. BUT, its enough lag that I think it would be bothersome for track duty.</p>
<p dir="auto">I want to reduce lag without hindering the top end pull too much.  There are a few different things I have in mind, but I need some input and opinions on what might be the best move to take to achieve the goal.</p>
<p dir="auto">A) Keep the same size+spec of turbo, but get a brand name version (Garrett/Turbonetics etc)    <strong>concern: might spend $$$ for little to no difference</strong></p>
<p dir="auto">B ) Keep the same size+spec of turbo, but get a ball bearing version (Either CX Racing OR Garrett/Turbonetics)</p>
<p dir="auto"><strong>concern: my research indicates that ball-bearing turbos are not rebuildable and are not as durable as journal bearing turbos, id hate to wreck one.</strong></p>
<p dir="auto">C) Go one size smaller CX Racing  T3/T4E .50A/R cold side (has a more modern compressor design as well)</p>
<p dir="auto"><strong>concern: might not reduce lag as much as id like it to, might lose more top end than id like to.</strong></p>
<p dir="auto">D)Get an adjustable cam gear to help the low end</p>
<p dir="auto">E) Increase compression ratio to 10.5:1 and run low boost (7-8psi max)</p>
<p dir="auto"><strong>concern: $$$$ + risky</strong></p>
<p dir="auto">F) Keep the turbo I have and do a stroker bottom end (2.8L), then make a decision after the larger refreshed bottom end.</p>
<p dir="auto"><strong>concern: I love the idea of staying stock bottom end 2.5L so that I can go to any old junkyard and be up and running easily after even the most serious snafu</strong></p>
<p dir="auto">other small tidbits to try</p>
<p dir="auto">G) weld a plate in my manifold to make it twin scroll and get a twin scroll turbo </p>
<p dir="auto"><strong>concern: my research indicates 4 cylinders benefit from twin scroll more than a 6 or 8 cyl, may not be worthwhile?? idk</strong></p>
<p dir="auto">H) Electronic boost controller</p>
<p dir="auto"><strong>concern: According to the Hallman boost controller website (what I have now), this boost controller is the shiz and is capable of outperforming some electronic units..... not sure if that is completely true</strong></p>
<p dir="auto">I) Get an adjustable BOV to ensure I am not losing any pressure while spooling (I have doubts about my used 1g DSM bov)</p>
<p dir="auto"><strong>concern: might not actually be a problem</strong></p>
<p dir="auto">In the research I have done (ive said that twice now) the difference in spool time between a journal bearing and ball bearing turbo is ~0.2-0.3 seconds,  on the other hand, I have seen a dyno comparing a properly sized journal bearing turbo vs a ball bearing turbo that was too large and the journal bearing turbo trumped it across the entire powerband. </p>
<p dir="auto">I am currently leaning towards C, and trying the .50 A/R col side CX Racing turbo. It is the cheapest and easiest option to try.</p>
<p dir="auto">Please share your thoughts and other ideas.</p>
<p dir="auto">This is the kind of response I am looking for</p>
]]></description><link>https://wibimmers.com/topic/2758/reducing-turbo-lag-what-should-my-next-step-be</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:09:12 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2758.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Jun 2014 00:24:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 23 Jun 2014 08:15:37 GMT]]></title><description><![CDATA[<p dir="auto">Oh my sides hurt</p>
]]></description><link>https://wibimmers.com/post/43711</link><guid isPermaLink="true">https://wibimmers.com/post/43711</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 23 Jun 2014 08:15:37 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 23 Jun 2014 02:48:27 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/tsar-bomba-1961.jpg" alt="tsar-bomba-1961.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/43704</link><guid isPermaLink="true">https://wibimmers.com/post/43704</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 23 Jun 2014 02:48:27 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 23 Jun 2014 02:35:00 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://img.tapatalk.com/d/14/06/23/gasasa8u.jpg" alt="gasasa8u.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/43702</link><guid isPermaLink="true">https://wibimmers.com/post/43702</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 23 Jun 2014 02:35:00 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 23 Jun 2014 02:27:50 GMT]]></title><description><![CDATA[<p dir="auto">weld the bov shut post results</p>
]]></description><link>https://wibimmers.com/post/43700</link><guid isPermaLink="true">https://wibimmers.com/post/43700</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 23 Jun 2014 02:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sat, 21 Jun 2014 20:49:17 GMT]]></title><description><![CDATA[<p dir="auto">Here is the latest  in my quest to spool sooner.<br />
I modified the blowoff valve because it sounded as if it was opening a bit prematurely, that doesnt seem to be the case but it does seem to be holding more after 8psi now so that's a win. <img src="http://i1278.photobucket.com/albums/y520/167901585/Threshold1_zps96ab8a28.jpg" alt="Threshold1zps96ab8a28.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/43643</link><guid isPermaLink="true">https://wibimmers.com/post/43643</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 21 Jun 2014 20:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 16 Jun 2014 13:02:29 GMT]]></title><description><![CDATA[<p dir="auto">I have a friend named Garrett.</p>
<p dir="auto">You be nice.</p>
]]></description><link>https://wibimmers.com/post/43310</link><guid isPermaLink="true">https://wibimmers.com/post/43310</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 16 Jun 2014 13:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 16 Jun 2014 12:49:41 GMT]]></title><description><![CDATA[<p dir="auto">Should have bought a turbo without such outdated design hehe. Gotta love Garrett. Let's bandaid our bad design with a ball bearing cartridge that can't be rebuilt!</p>
]]></description><link>https://wibimmers.com/post/43309</link><guid isPermaLink="true">https://wibimmers.com/post/43309</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Mon, 16 Jun 2014 12:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Mon, 16 Jun 2014 01:16:53 GMT]]></title><description><![CDATA[<p dir="auto">Because Rocketship!</p>
]]></description><link>https://wibimmers.com/post/43263</link><guid isPermaLink="true">https://wibimmers.com/post/43263</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 16 Jun 2014 01:16:53 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 17:15:43 GMT]]></title><description><![CDATA[<p dir="auto">So there is no turbo lag</p>
]]></description><link>https://wibimmers.com/post/43246</link><guid isPermaLink="true">https://wibimmers.com/post/43246</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sun, 15 Jun 2014 17:15:43 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 16:47:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/43168">TehRaydarlover said:</a></strong></p>
<p dir="auto">E30 anti-lag coming soon to a quiet suburb near you.</p>
<p dir="auto">I've watched this video 20+ times and I still giggle like a little school girl</p>
<p dir="auto">The only thing that comes to mind is "why?"...</p>
]]></description><link>https://wibimmers.com/post/43244</link><guid isPermaLink="true">https://wibimmers.com/post/43244</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Sun, 15 Jun 2014 16:47:32 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 16:37:00 GMT]]></title><description><![CDATA[<p dir="auto">I ordered a performance clutch from UUC but I'm still waiting for it to come in.</p>
]]></description><link>https://wibimmers.com/post/43243</link><guid isPermaLink="true">https://wibimmers.com/post/43243</guid><dc:creator><![CDATA[frcefed]]></dc:creator><pubDate>Sun, 15 Jun 2014 16:37:00 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 16:35:12 GMT]]></title><description><![CDATA[<p dir="auto">'Part throttle is faster than full throttle' I know! I always thought there was something wrong with my turbo or something. Haha</p>
]]></description><link>https://wibimmers.com/post/43242</link><guid isPermaLink="true">https://wibimmers.com/post/43242</guid><dc:creator><![CDATA[frcefed]]></dc:creator><pubDate>Sun, 15 Jun 2014 16:35:12 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 13:49:50 GMT]]></title><description><![CDATA[<p dir="auto">Haha! Mine does as well so its somewhat humorous that part throttle is faster than full throttle sometimes. Id really like to check it out sometime though</p>
]]></description><link>https://wibimmers.com/post/43238</link><guid isPermaLink="true">https://wibimmers.com/post/43238</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 15 Jun 2014 13:49:50 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 13:39:03 GMT]]></title><description><![CDATA[<p dir="auto">Well its only supposed to be 15psi but my boost controller sucks and anything over 13psi and my clutch slips anyway. Ha</p>
]]></description><link>https://wibimmers.com/post/43237</link><guid isPermaLink="true">https://wibimmers.com/post/43237</guid><dc:creator><![CDATA[frcefed]]></dc:creator><pubDate>Sun, 15 Jun 2014 13:39:03 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 05:51:51 GMT]]></title><description><![CDATA[<p dir="auto">Good to know. I cant fathom 20psi</p>
]]></description><link>https://wibimmers.com/post/43233</link><guid isPermaLink="true">https://wibimmers.com/post/43233</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 15 Jun 2014 05:51:51 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Sun, 15 Jun 2014 05:19:19 GMT]]></title><description><![CDATA[<p dir="auto">I have the same dimensions on my Garrett t3t4 with ball bearings (and a warranty, thanks todd:)) and I have quite a bit of lag too, boost builds around 2600 and I hit 20psi around 4300rpms. I've been thinking about going the adjustable cam gear route.</p>
]]></description><link>https://wibimmers.com/post/43232</link><guid isPermaLink="true">https://wibimmers.com/post/43232</guid><dc:creator><![CDATA[frcefed]]></dc:creator><pubDate>Sun, 15 Jun 2014 05:19:19 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Fri, 13 Jun 2014 18:31:34 GMT]]></title><description><![CDATA[<p dir="auto">I like the burnt portion of the strap</p>
]]></description><link>https://wibimmers.com/post/43169</link><guid isPermaLink="true">https://wibimmers.com/post/43169</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 13 Jun 2014 18:31:34 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Fri, 13 Jun 2014 18:16:38 GMT]]></title><description><![CDATA[<p dir="auto">E30 anti-lag coming soon to a quiet suburb near you.</p>
]]></description><link>https://wibimmers.com/post/43168</link><guid isPermaLink="true">https://wibimmers.com/post/43168</guid><dc:creator><![CDATA[TehRaydarlover]]></dc:creator><pubDate>Fri, 13 Jun 2014 18:16:38 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Fri, 13 Jun 2014 13:11:39 GMT]]></title><description><![CDATA[<p dir="auto">Megasquirt</p>
<p dir="auto">Everything can be logged.  everything and more</p>
]]></description><link>https://wibimmers.com/post/43155</link><guid isPermaLink="true">https://wibimmers.com/post/43155</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 13 Jun 2014 13:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Fri, 13 Jun 2014 13:03:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/43112">Rowleym said:</a></strong></p>
<p dir="auto">Anything specific he should datalog?</p>
<p dir="auto">Everything.  The more data available the better.   Snap - which datalogging capabilities is TCD speaking of?  How is your car setup today?</p>
<p dir="auto">FWIW, when I log my car (jb4 equipped) I get all possible data available via the OBD2 port.  That way I can display anything/everything I want when addressing a possible issue with the tune/car/setup/etc.</p>
]]></description><link>https://wibimmers.com/post/43153</link><guid isPermaLink="true">https://wibimmers.com/post/43153</guid><dc:creator><![CDATA[Narcosis]]></dc:creator><pubDate>Fri, 13 Jun 2014 13:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Thu, 12 Jun 2014 23:45:28 GMT]]></title><description><![CDATA[<p dir="auto">log all the things</p>
]]></description><link>https://wibimmers.com/post/43116</link><guid isPermaLink="true">https://wibimmers.com/post/43116</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 12 Jun 2014 23:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Thu, 12 Jun 2014 23:28:29 GMT]]></title><description><![CDATA[<p dir="auto">Anything specific he should datalog?</p>
]]></description><link>https://wibimmers.com/post/43112</link><guid isPermaLink="true">https://wibimmers.com/post/43112</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 12 Jun 2014 23:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Wed, 11 Jun 2014 23:17:21 GMT]]></title><description><![CDATA[<p dir="auto">If you take a data driven approach to building/tuning your car you will be much better off.  Guessing at solutions doesn't work.  You have fantastic data logging capabilities.  You need to use them.</p>
]]></description><link>https://wibimmers.com/post/43034</link><guid isPermaLink="true">https://wibimmers.com/post/43034</guid><dc:creator><![CDATA[TCD]]></dc:creator><pubDate>Wed, 11 Jun 2014 23:17:21 GMT</pubDate></item><item><title><![CDATA[Reply to Reducing turbo lag: What should my next step be? on Wed, 11 Jun 2014 00:46:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the input Rowley</p>
<p dir="auto">I added some timing advance down low and will be doing the "Dodge Garage" modification to my blowoff valve because I know it is bleeding off some pressure under WOT and shall see how things improve there.</p>
]]></description><link>https://wibimmers.com/post/42932</link><guid isPermaLink="true">https://wibimmers.com/post/42932</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 11 Jun 2014 00:46:06 GMT</pubDate></item></channel></rss>
