pistonse30
    No dice on the GSR pump.
    I think I will get a replacement for the pump I already have and weld that nut.
    With the savings I will more than likely get the harmonic dampener to try to calm down that engine and prevent anything else from rattling/snapping loose.
      If you ain't breakin' parts, you ain't makin' nuff powa!
        If you ain't mixin' gas, you ain't hauling ass.
        You should see my weed whacker whack weeds.
          #6 bottom rod bearing. Looks good to me!
            Talk about a bearing relief
            hawhawhawhaw
              hawhawhawhaw
              Gonna get 100% confirmation from my machinist right now.
                http://www.achillesmotorsports.com/Achilles-Motorsports-Upgraded-Oil-Pump-New-BMW-M-p/11-am-uopn.htm
                I just ordered this along with their oil pan baffle.
                I also bought a new Jesus bolt and washer to go with it.  While I was turning over the motor to pull the #6 rod bearing I noticed the bolt loosening while the crank was staying in the same place.  I'm glad I found this before it broke again.
                  I'm also going to check all of my rod bearings for wear. Boris with the 8 second independent rear suspension e30 talked me into it.
                  He said the ARP bolts need to be torqued to 43ft/lbs with the ARP torque lube. That's better than doing the 25ft/lbs then turned an additional 55 degrees that K1 told me to do.
                    I have  mine torqued up around 70 ft-lb per VAC Motorsports' instructions. They appear to be for both 12v and 24v engines. I can scan them if you would like.
                      p
                      Yes please.
                        DrLeadFoot said:
                        I also bought a new Jesus bolt and washer to go with it.  .
                          Did you call ARP yet? I hope you did. I went out of my way to give you their number
                            I will today as well as pick up my parts from Concours.
                            It's been a little nuts these past 72 hours with work. ;) more info to come later.
                              Oil pan gasket.
                              Jesus bolt and his ring.
                              More parts to come!
                                Parts have arrived!
                                I'm going get new ARP rod bolts and mic them before install so if I need to pull them again I can be 100% sure if I can reuse them or not.
                                  Baffle buddies unite!
                                    Time for an update.
                                    Dropped off my oil pan and baffle at the welder yesterday. I should get it back in 2 days.
                                    This afternoon I will order new ARP rod bolts. Then track down my Snap-On guy to get a degree torque tool for measuring the 55° after the bolts are torqued to 25 ft/lbs.
                                    I've been pulled away from the car due to a job change. I'm officially a Realtor for Coldwell Banker Residential Brokerage! I've been doing rental properties for the past 4 years and now I will continue the rentals as well as adding sales into my routine.
                                    With that being said let me know of anyone looking to buy/sell/rent a property and I can give referrals to other agents, if I couldn't effectively help myself, nationwide. As an incentive I will let anyone drive the e30 if the leads are solid!
                                    I want to go fast, fast!!
                                      The job change is exciting!   congratulations on that and I hope you like it better.
                                      FYI  when I gave you the ARP customer support line, I actually gave you the AARP customer support line and I would have loved to hear about the strange conversation you would have had about bolt torque specs with a retirement benefit personnel.
                                      I'll get you next time.
                                        Definitely congrats on the new position John!
                                          Haha.
                                          Thanks guys!
