pistonse30
    Trans inspection cover gets removed to get the last few screws out. Hope the results come back okay
    Is that the sheet metal piece that can only be removed by removing the trans?
      Nope its the bottom half of the bellhousing, cast aluminum piece. Held on with a few inverted torx bolts
        Thank you!
          I don't have an access panel on the trans. I'm going to loosen the trans a lot more and see what happens.
            Snap is thinking the bowl reinforcment that the 12v engines have.  24v doesn't have this.  You should not have to loosen the transmission.  Are you sure it is not just RTV "gluing" it on?
              I'll give it another good prying. I was getting nervous about breaking it before.
                As long as you got all of the bolts out it should come off, use a putty knife to work it off of there.  I'm sure you did, but double check the perimeter for any bolts that you could have missed.  There are a couple at the back that are long if I remember right that go into the rear main seal housing but they are the same diameter as all of the rest.  If you still have trouble I have a spare oil pan that I could take a pic of.
                  I just found my motivation. Just raced a Viper on the freeway in the M3. Needless to say I need a turbo in my life at all times. Sunday is go time.
                    ^ H3 GON3
                      B33R HIM
                        Finally! As I suspected but a little worse. Must have had loosened up and was turning it at weird angle so it sheared off. #powerproblems #havearaceshopbuilditnexttime
                        What was in the bottom of the pan.
                          I think this is the best option.
                          http://store.bimmerworld.com/gsr-m52m54-four-bolt-oil-pump-shaft-p2210.aspx
                            Glad you got the pan off. The chain driving the oil pump is a different one from the cams, right? Any oil analysis results yet
                              There are two different chains.  One guy on R3V said that the tensioner would have been affected but the tensioner only touches the timing chain not the oil pump chain.  I'm confused about that.
                              No results yet since I haven't mailed it.  The sample I took won't be 100% accurate because, as you know, you need to heat up the oil and mix it up.  I took the sample when the oil was about half way done draining.  I will be monitoring the oil closely from here on out just so I know when to replace my bearings.
                                Are you anticipating a rebuild/new bearings kind of no-matter what? Or making a decision based on the results?
                                  Based on results. The oil was newer and I caught it pretty quick I think. If it is okay I will shout the praises of Royal Purple from the mountains. A little worried about my turbo shaft play doe.
                                    note to self....
                                    never turbo anything, ever
                                    drive camrys till the day i die
                                    • T
                                      T
                                      tsweers89
                                      Why wasn't this nut welded when it was put together at the very minimum? Knowing that these are known issues its something that shouldnt of happened in the first place. Also many many people go with the vac motorport oil pump upgrade which includes a hardend oil pump shaft. I don;'t know about the one you posted but that is an option as well. But do as you please. Also some of the older m50's have chain tensioners on the oil pump chain. Yours does not. Again some opt and add a Euro oil pump chain guide/tensioner or a s54 chain tensioner for the oil pump. Not 100% needed but something id consider if you are reving it high often.
                                        This, yours was safety wired?
                                        I welded mine when I built my m50, it has survived 45k of bouncing off of the rev limiter.  I am NA though, but that wouldn't really affect the oil pump.
                                          It was not welded or safety wired. I didn't know about this and that is why I brought it to a shop... There was a lock washer installed but I don't think that was in the Bentley manual.
                                          I'm going to do some more research to see if I can get the GSR pump to work with my current pump otherwise I will try to retrofit a m54 or m52 5 bolt pump in there. (I think this is right). If I need to weld a shorter pickup on one so be it.
                                          I am worried about breaking the shaft aswell as the nut coming loose. This motor revs so fast!
