    I swear no one in the shop can draw anything except for dicks. WHAT THE HELL. Sick of having every shape of penis on my car.
      Achieved zero progress over the weekend. The girlfriends rear drums brakes proved to be a weekend long endeavor.
      These came in however:
      I will be installing those Saturday, as well as installing my new sway bar endlinks, bushings, brackets, and hardware.
      I will also be getting the inside of the valve cover cleaned out and then installing it for good on the engine.
      I gave my friend Greaser Kyle the pass code for the garage door so that he can work on the bay/shaving while I am not there so we can get this done=)
        Derflaminflitzer
        56 pages and the car doesnt run....im starting to feel a bit let down earl.
          Lol
            Derflaminflitzer
            If there is anything I can do to help speed this up without the cost of my money I will. Time is not money in this case
              Lol
              Lol
              • StewCrewS
                StewCrewS
                StewCrew
                Lol
                Lol
                • StewCrewS
                  StewCrewS
                  StewCrew
                  Lol
                  Lol
                  Lol
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    hey stewcrew how did you get such a big pic on ur sig?
                    1988 BMW 528e - Need parts?
                    1996 Mazda Miata (SOLD!!!)
                    1996 BMW 325i (Donor car)
                      it's been there for forever
                        I made the purchase of a more period correct steering wheel yesterday=)
                        This means that my Grip Royal Grain with the horn button will be for sale shortly.
                        Obviously it is in brand new shape since the car has never been driven with it and I bought it brand new.
                        The new wheel is an Italvolanti that I found for an excellent price and it was one of the only wheels that I could find that I thought would flow well with the OEM+ vibe and is 350mm.
                        I will post a pic once it arrives and is installed so that I can make sure it looks as fitting as I am hoping.
                        Other than that I painted the proper side of my waterpump pulley last night since I painted the wrong side before=P
                        Saturday should involve me installing my Ground Control RSMs, swaybar endlinks/bushings/brackets/hardware, and possibly starting to replace the wheel bearings.
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          I'm not sure hahah. I just went off the specs the website gave me for sizes!
                            I got my Ground Control rear shock mounts installed Saturday.
                            Here is the set of e46 m3 vert mounts that I replaced (less than a years worth of driving on them)
                            New versus old
                            fc368f76-f202-4ebf-905f-704d7de4397bzps
                            Installed top plates
                            Then installed the shocks with the mounts
                            Also installed the new lower shock mounting bolts
                            After that I removed the rear sway bar to sandblast, repaint (not happy with how it looks from before), and then to prepare for the new bushings, brackets, end links, and hardware.
                            I noticed that the under side of my diff surface rusted through the rust reformer/paint and that my trailing arms are starting to do the same around the edges. I have been thinking of dropping the sub frame again to replace all of the bolts with new and this has me wanting to repaint it all again. I am not sure why said rust reformer would not have neutralized the rust like it looked like it had=/
                              After that I got the thermostat and housing installed with the gaskets, as well as the water pump pulley
                              The pile of scrap from the end of the day
                              After that I cruised up to Oshkosh for Collins BBQ=)
                              I now have an m44 crank pulley on the way and will have my new steering wheel and misc parts within the next month.
                                3349304+eaaec8b8577210efc5fd70b9afeb86d
                                also
                                I spy an engagement ring
                                  This ring has been on my finger for almost four years. No engagement here=)
                                  Also, I don't want the diff and trailing arms to be rusty. Not sure how it even happened since it had rust reformer and was rustoleum paint.
                                    I would use some serious paint like KBS rustseal, it is very easy and looks good when done, I prefer the gloss black.  You can buy it on their website or Napa usually stocks it, at least mine does.  Rustoleum paint has not been very durable in my experience.
                                      I was thinking about grabbing some of that for when I seal my front inner fenders=) I will have to look into it. It wouldn't take any more than 15 minutes to drop the subframe again and a day to redo the paint.
                                        It is very durable, I just brush it on, it self levels nicely to a nice smooth surface.
                                          My m44 crank pulley showed up yesterday=)
                                          I gave it a quick wash
                                          Then I gave it a coat of paint
