  4. New ride! 89 e30 vert
summertime rage
141 Posts 18 Posters 1.6k Views 3 Watching
    Got some work done yesterday.  Pulled the drive shaft and found this.
    Anybody here seen the cam belt ride way to the front and rub on the covers?
    Appears this has been worked on before, and they forgot to put something back...
    I love you late m20 and your plug in fuel injector harness goodness also it's way better with both fuel lines at the front of the rail.
    Engine is grimy but looks great
    Coolant has been flushed regularly, this is the best I have seen inside, no rust or scale inside the block or head.
    Got the trans out, never pulled an auto before so I dumped all the fluid from the torque converter out, caught half of it in a bucket luckily but still made a mess.
    Goodbye evil slushbox!
    Also this is getting expensive, just made a $625 order from Pelican to hopefully have everything I need.
    WTB cap and rotor, Rowley, message me back.
    Little bracket thing for the back of the shift linkage: wasn't going to pay the 50 bucks for a new one, somebody has to have one.
    PM me asap if you have any of this.
      Ramze46 said:
      you need these wheels for your e30
      Ah, yes,  MiM 1900's
      I like those, they remind me of Alpina wheels, what are they?
      MiM 1900's
      Ramze46 said:
      snap should know they look oem to me
      They are MiM 1900's
      CYoung said:
      He doesn't know everything!
      Very true! but I do know how to multiquote.
        If anyone spots a set let me know, they look sweet.  And a little different than everyone with basketweaves.
          Got the pedals in.
          Adjusted valves, and installed exhaust manifolds with new gaskets, not sure why they are different, they were in the same packaging from Victor Reinz.
          Also I love stickers!!!!
            Got started tonight around 9,  Fedex package came, it's Christmas!!!
            Replaced cam seal and o-ring, and installed water pump
            Valve cover gasket and rocker arm shaft plugs replaced.  Top end looks very clean, this car has been taken care of over the years.
            Timing belt on.
            And timing belt covers installed.
            Now I had better go to bed so I can get up at 5am for work tomorrow, I am super excited to drive this thing, the only time I have driven it is in reverse a half mile from the storage unit to my house (Mike you should try to post the video).
              Bring it to the e30 picnic!
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Been trying my phone is being a typical iphone and wont let me send vids to youtube i can try to email you the vid or i can send it to someones smartphone maybe
                1988 BMW 528e - Need parts?
                1996 Mazda Miata (SOLD!!!)
                1996 BMW 325i (Donor car)
                  Got alot done on Monday, New engine mounts.  Lowriders guys, you can gain a quarter inch of oil pan clearance by replacing your junk motor mounts.  My engine was pretty much sitting on the steering rack.
                  New rear main seal and all cleaned up.
                  Different sizes of PVC fittings work awesome as seal drivers.
                  New cap and rotor, old one was pretty rough, thanks Nick!
                  My helpers for a while.
                  Then Mike and Ben came over and we really moved.  Head cleaned up and ready for the intake.
                  Transmission in.  That looks so much nicer under there, Mike and I took the transmission to the quarter car wash and pressure washed it, not as nice as Ben's but much better.
                  How she sits right now, after work tonight I will get a few more things buttoned up.  I need to replace the muffler and just want a dual in/dual out, weld in one, any recommendations?
                    bfinley
                    No yours looks better because it's in the car ^^^ can't wait for dirty 30 burnout a
                      It is getting close, not much time to work on as I am working 10hr shifts at work but I have Sun/Mon off.
                      To do:
                      Tighten drive shaft to differential bolts
                      Replace fuel filter
                      Weld muffler onto my cat back pipes and install (Thanks Andy! it looks great)
                      Install new front control arm bushings
                      Install radiator and hook up coolant hoses
                      Replace battery clamps, tightening bolts are seized up
                      Install air box and AFM
                      Change transmission fluid
                      Fill engine oil
                      Fill coolant
                      Turn key!!!
                        Exhaust is done, Control arm bushings are pressed into the lollipops, air chisel works awesome for removing the old ones.  I forgot on the list that the clutch needs to be bled too.  Tomorrow is the day hopefully.
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          Really think you need to one up this dude noaw!!!
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            exhaust vids then!
                            • RamRod E28R
                              RamRod E28R
                              RamRod E28
                              I think ur e30 is due for this
                                Noon update.
                                Replace fuel filter, pretty sure it's been on there for 25 years.
                                Fab mount for exhaust to manual trans.
                                Bleed clutch and brakes, fluid is extremely disgusting
                                Fill engine oil
                                Fill coolant
                                Turn key!!!
                                  Noon update.
                                  Fill engine oil
                                  Fill coolant
                                  DO BURNOUTS
                                  Turn key!!!
                                  Added the most important step
                                    This is awesome, Keep it up man!
                                      You talk a big game. Still waiting on your burnout vids dood! :P
                                        Got a lot done yesterday, I will get some pics up later.
                                        Bleed clutch and brakes, fluid is extremely disgusting, ran out of fluid before I got to the clutch, Flushed a quart through the brakes though and got a lot of junk cleaned out
                                        Change differential fluid
                                        Fill engine oil
                                        Fill coolant
                                        Install clutch switch and make wiring splices.
                                        Turn key
                                        Burnouts!
                                          Looking good!!! Reading through your list has reminded me of some things I should do.
                                          Aaaannndddd...... In for burnout video.
