  4. New ride! 89 e30 vert
summertime rage
141 Posts 18 Posters 1.6k Views 3 Watching
    bfinley
    John,
    Thanks for letting Damian and I stop by yesterday. The 'vert is even prettier in person.
    As we were leaving Damian goes "your friends really nice but I kind of hate him right now" he spent the rest of the day about how you got a clean e30 vert for cheap monies
    • RamRod E28R
      RamRod E28R
      RamRod E28
      you need these wheels for your e30
      1988 BMW 528e - Need parts?
      1996 Mazda Miata (SOLD!!!)
      1996 BMW 325i (Donor car)
        I like those, they remind me of Alpina wheels, what are they?
        • RamRod E28R
          RamRod E28R
          RamRod E28
          snap should know they look oem to me
            He doesn't know everything! They aren't OEM E30 wheels as style 32's are 18 spoke and didn't come that small. My best guess was Hartge but those are 12 spoked and I genuine hartge's are 11 spoke.
              Got some work done yesterday.  Pulled the drive shaft and found this.
              Anybody here seen the cam belt ride way to the front and rub on the covers?
              Appears this has been worked on before, and they forgot to put something back...
              I love you late m20 and your plug in fuel injector harness goodness also it's way better with both fuel lines at the front of the rail.
              Engine is grimy but looks great
              Coolant has been flushed regularly, this is the best I have seen inside, no rust or scale inside the block or head.
              Got the trans out, never pulled an auto before so I dumped all the fluid from the torque converter out, caught half of it in a bucket luckily but still made a mess.
              Goodbye evil slushbox!
              Also this is getting expensive, just made a $625 order from Pelican to hopefully have everything I need.
              WTB cap and rotor, Rowley, message me back.
              Little bracket thing for the back of the shift linkage: wasn't going to pay the 50 bucks for a new one, somebody has to have one.
              PM me asap if you have any of this.
                Ah, yes,  MiM 1900's
                MiM 1900's
                They are MiM 1900's
                Very true! but I do know how to multiquote.
                  If anyone spots a set let me know, they look sweet.  And a little different than everyone with basketweaves.
                    Got the pedals in.
                    Adjusted valves, and installed exhaust manifolds with new gaskets, not sure why they are different, they were in the same packaging from Victor Reinz.
                    Also I love stickers!!!!
                      Got started tonight around 9,  Fedex package came, it's Christmas!!!
                      Replaced cam seal and o-ring, and installed water pump
                      Valve cover gasket and rocker arm shaft plugs replaced.  Top end looks very clean, this car has been taken care of over the years.
                      Timing belt on.
                      And timing belt covers installed.
                      Now I had better go to bed so I can get up at 5am for work tomorrow, I am super excited to drive this thing, the only time I have driven it is in reverse a half mile from the storage unit to my house (Mike you should try to post the video).
                        Bring it to the e30 picnic!
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          Been trying my phone is being a typical iphone and wont let me send vids to youtube i can try to email you the vid or i can send it to someones smartphone maybe
                            Got alot done on Monday, New engine mounts.  Lowriders guys, you can gain a quarter inch of oil pan clearance by replacing your junk motor mounts.  My engine was pretty much sitting on the steering rack.
                            New rear main seal and all cleaned up.
                            Different sizes of PVC fittings work awesome as seal drivers.
                            New cap and rotor, old one was pretty rough, thanks Nick!
                            My helpers for a while.
                            Then Mike and Ben came over and we really moved.  Head cleaned up and ready for the intake.
                            Transmission in.  That looks so much nicer under there, Mike and I took the transmission to the quarter car wash and pressure washed it, not as nice as Ben's but much better.
                            How she sits right now, after work tonight I will get a few more things buttoned up.  I need to replace the muffler and just want a dual in/dual out, weld in one, any recommendations?
                              bfinley
                              No yours looks better because it's in the car ^^^ can't wait for dirty 30 burnout a
                                It is getting close, not much time to work on as I am working 10hr shifts at work but I have Sun/Mon off.
                                To do:
                                Tighten drive shaft to differential bolts
                                Replace fuel filter
                                Weld muffler onto my cat back pipes and install (Thanks Andy! it looks great)
                                Install new front control arm bushings
                                Install radiator and hook up coolant hoses
                                Replace battery clamps, tightening bolts are seized up
                                Install air box and AFM
                                Change transmission fluid
                                Fill engine oil
                                Fill coolant
                                Turn key!!!
                                  Exhaust is done, Control arm bushings are pressed into the lollipops, air chisel works awesome for removing the old ones.  I forgot on the list that the clutch needs to be bled too.  Tomorrow is the day hopefully.
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    Really think you need to one up this dude noaw!!!
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      exhaust vids then!
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        I think ur e30 is due for this
                                          Noon update.
                                          Replace fuel filter, pretty sure it's been on there for 25 years.
                                          Fab mount for exhaust to manual trans.
                                          Bleed clutch and brakes, fluid is extremely disgusting
                                          Fill engine oil
                                          Fill coolant
                                          Turn key!!!
