  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
do it myself
192 Posts 14 Posters 3.4k Views 3 Watching
    bfinley
    Well I decided to spend the weekend pulling the motor, and help do head gaskets on one car and install coilovers on another... Busy busy.
    After two days of shop shenanigans and working in a shop barely above freezing All that did get accomplished, and I discovered that the previous owner welded the bumper to the fenders and the buried the joint under a quarter inch of bondo... Not amused
      Weight savings, no bolts needed.
      Looking good!  I am off tues-thurs this week so I will try to make a template of the e30 wheel arch.
      Is that Miata owned by a guy named Chris?
        I dont think so, that doesn't look like Chris' boyfriend, but you know how Miata guys get around.
          bfinley
          John at least they could have done a better job with the welds ! that template would be awesome so I can move on those kamotors flares.
          Snap, truth about miata guys. This one belongs to a local tuner, Matt schreck. It's affectionately named the unicorn and is going to get giant googly eyes and rainbow decals
          • RamRod E28R
            RamRod E28R
            RamRod E28
            bfinley said:
            John at least they could have done a better job with the welds ! that template would be awesome so I can move on those kamotors flares.Snap, truth about miata guys. This one belongs to a local tuner, Matt schreck. It's affectionately named the unicorn and is going to get giant googly eyes and rainbow decals
            That is hilarious!
            1988 BMW 528e - Need parts?
            1996 Mazda Miata (SOLD!!!)
            1996 BMW 325i (Donor car)
              bfinley
              Transmission is out, driveshaft, glass, and dash are next.
              Did some exploratory wire brush grinding in the trunk which revealed fiberglass covering welded patch panels... And am now covered in fiberglass slivers ...
              I'm glad I don't have to do all the patches, but I'm pretty sure a blind monkey can weld better than this
                bfinley
                I forgot the pink fiberglass insulation I found wired and melted to the top of the trans. I'll find a picture of that very custom mod...
                  Might as well use fiberglass everywhere right?
                    bfinley
                      Gotta love PO nightmares.
                        bfinley
                        Anyone know if the 4 speed linkage is drastically different than the 5 speed ?
                          From that pic it looks like selector rod is very long.  I would think it is very similar though, what is the date on your g260?  Early ones have a steel plate carrier like the one on your 4spd, late ones have an aluminum shift carrier.  And some in the middle have provisions for both.  The date should be inside the bellhousing I think.
                            bfinley
                            That's why I'm thinking I could chop mine down to size but it's probably easier to pull one out of an e30 ...
                            I'll check for a date on the trans tonight
                              That carrier looks quite different than the early 260 one.  Went back to your pic and it has the spot above the shift link on the back for the aluminum carrier, see if the holes below that on the back are tapped or not, hard to see in the pic but it looks like it has the spots for the eta sensors on the drivers side of the bellhousing.
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                If the holes are there it'll b a direct bolt on plug n play senario for the eta ur getting off me
                                  bfinley
                                  Mr. Menard made these templates from his e30 vert to see if I can run e30 flares on the e21 I think they will fit!
                                  Thank you sir!
                                    I thought you were going to make skirts to cover the well!
                                      bfinley
                                      Spent the day tearing down the old m10 motor and drinking beer in the shop. I'm planning to clean it up maybe paint it and then weld it into a coffee table or something.
                                      For having 36 years of wear and tear she wasn't in awful condition
                                      • RamRod E28R
                                        RamRod E28R
                                        RamRod E28
                                        Coulda sent me a text im always down for working on bmws and drinking beer as well lol also found this vid for a little inspiration.
                                          bfinley
                                          Ah! Next time I will do so !
