  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
192 Posts 14 Posters 0 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    bfinley said:
    John at least they could have done a better job with the welds ! that template would be awesome so I can move on those kamotors flares.Snap, truth about miata guys. This one belongs to a local tuner, Matt schreck. It's affectionately named the unicorn and is going to get giant googly eyes and rainbow decals
    That is hilarious!
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      bfinley
      Transmission is out, driveshaft, glass, and dash are next.
      Did some exploratory wire brush grinding in the trunk which revealed fiberglass covering welded patch panels... And am now covered in fiberglass slivers ...
      I'm glad I don't have to do all the patches, but I'm pretty sure a blind monkey can weld better than this
        bfinley
        I forgot the pink fiberglass insulation I found wired and melted to the top of the trans. I'll find a picture of that very custom mod...
          Might as well use fiberglass everywhere right?
            bfinley
              Gotta love PO nightmares.
                bfinley
                Anyone know if the 4 speed linkage is drastically different than the 5 speed ?
                  From that pic it looks like selector rod is very long.  I would think it is very similar though, what is the date on your g260?  Early ones have a steel plate carrier like the one on your 4spd, late ones have an aluminum shift carrier.  And some in the middle have provisions for both.  The date should be inside the bellhousing I think.
                    bfinley
                    That's why I'm thinking I could chop mine down to size but it's probably easier to pull one out of an e30 ...
                    I'll check for a date on the trans tonight
                      That carrier looks quite different than the early 260 one.  Went back to your pic and it has the spot above the shift link on the back for the aluminum carrier, see if the holes below that on the back are tapped or not, hard to see in the pic but it looks like it has the spots for the eta sensors on the drivers side of the bellhousing.
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        If the holes are there it'll b a direct bolt on plug n play senario for the eta ur getting off me
                          bfinley
                          Mr. Menard made these templates from his e30 vert to see if I can run e30 flares on the e21 I think they will fit!
                          Thank you sir!
                            I thought you were going to make skirts to cover the well!
                              bfinley
                              Spent the day tearing down the old m10 motor and drinking beer in the shop. I'm planning to clean it up maybe paint it and then weld it into a coffee table or something.
                              For having 36 years of wear and tear she wasn't in awful condition
                              • RamRod E28R
                                RamRod E28R
                                RamRod E28
                                Coulda sent me a text im always down for working on bmws and drinking beer as well lol also found this vid for a little inspiration.
                                  bfinley
                                  Ah! Next time I will do so !
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    yeah dude do! I shall b down tomorrow to help john on his e30
                                      bfinley
                                      Really wallowing in the "what did I get myself into" mood this evening. Took the grinder to ever rust bubble in the paint I could... Rockers are gone, front fenders will probably be replaced along with the floor pans.
                                      Gonna make a big push this weekend to get the glass out and then buy paint stripper. We're going to take her down to bare metal
                                        When a car goes down to bare metal, what is done to prep it for paint to prevent humidity in the air from propagating microscopic rust spots that will grow under the paint?
                                          I have been thinking the same about my e36, why did I take my summer daily apart... If you want to use my sandblaster you are welcome to.
