    Can't wait to see this in person!  Super clean bay!  Epic wire tuck.
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Thanks guys! I'll crash a BMW meet or two in this car this summer... park on the street or something. I can't wait for the meet "season" to get going.
      Progress and such. In-fender wiring pretty far along now. Waiting for the intake manifold to show up to finalize all the wiring that will be hidden under that.
        Looking topnotch as usual! Can not wait to see this car in person!
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Thanks TJ
          Test-fit with the intake manifold. looks like the new fuel rail interferes with the strut brace, so that'll take some figuring.
          Freshened up (thanks DP)
          BRAKES
          These 17" RCs barely clear the caliper. Perhaps a bit close for comfort.
            I thought my brake setup was cutting it close.  e46 330i brakes (325mm) with 16" contour reps.  I have less than 1/4" clearance.  From the pic it looks like tons of room for the caliper.
            • The Full BananaT
              The Full BananaT
              The Full Banana
              The picture does look roomy, especially with the adapters on there. There is 1/16"-3/32" clearance between the caliper and the barrel of the wheel. It's VERY tight.
                On the bright side, it will be an automatic indicator if a wheel gets bent.
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  Getting more things done.
                  Mocking up the intercooler--not yet mounted.
                  Intercooler pipes fitted.
                  Roundit 2000 for the harness and misc other wiring
                  Odyssey PC680 mounted and other bits
                    Good progress!  I like the sneaky battery mounting
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      Thanks, I'm going to use a e36 distribution block/positive terminal in the engine bay. Should be a nice little detail.
                        I hope you make it out to the E30 meet on May 10th.
                        This car is awesome
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          If you guys don't mind me bringing a non-BMW, I'd like to swing by. We'll see though, that is two days before I take this car on a 35 hour drive to Portland, OR for a Volvo car show.
                            That should be a great drive! Are you taking I80 or I90?
                            Did you come up with that oil cooler bracket or is that original?
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              We are just going to start figuring out the route now. At the moment, I have no idea... but I'm very open to suggestions! We will probably be stopping in Kansas City on the way out.
                              That oil cooler is a factory piece from a mid-year turbo car. It fits rather nicely with the factory intercooler in place, but the endtanks on this one block it more than I would like. I may try a bit of ducting to direct air to it... or I'll eventually put an oil cooler below the radiator. I have an oil temp gauge so I can keep an eye on it (Not that it should present any problem).
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                I'm tired and it's late so I'm not going to write much.
                                I've been working on this a lot, and had help this weekend. A couple friends came over and swapped in the rear end from the wagon while I worked on other stuff.
                                (oil lines aren't going to just hang there... have to wrap and mount them still)
                                this one is for Dave.
                                Goal was to start it today but that didn't happen because I was missing a few little bits and pieces that local stores didn't have. I'm going to get this thing legal to drive this week... it won't be long now.
                                  Looking great!  Did it always have the remote oil filter?
                                    The Full Banana said:
                                    This entire build was a steaming heap of crap up until the point you installed the brackets powdercoated by bassboy. Bassboy saves the day!
                                    Oh, and black-oxide socket head cap screws? NOT EARL APPROVED IN THE LEAST
                                    Were the charge pipes part of a kit, or did you select them all yourself?
                                      Everything is looking amazing man! Glad the brackets worked out and are looking sharp too! :) Thanks for the pic!
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        Nope, didn't have the remote oil filter, but it was something I swore to add when I had my wagon.
                                        With a turbo and whatnot in there, it's way more of a pain to get the filter off the stock location than it should be. In this spot i should just be able to lay on the ground and reach up to get it off. Also the added bonus of there not being anything scalding hot nearby.
                                        Stainless bling all over the place is not my thing. Also, this is a car for driving.   ;)
                                        The black pipes are some Volvo factory pipes off of a few different early 90s turbo cars that I had laying around and cut for my needs. The silver pipes, couplers, and t-bolt clamps are all from a CX-racing 2.5" IC pipe kit.
                                        Thanks! I have some more things in my trunk right now...
                                          Feel free to drop them off whenever you would like. Shoot me a text or something.
