    Looking good, I have a bunch of parts getting powdered right now.
      The vecotr is cool....doesn't appear to be low enough.
        He made the frame rails a little high. E36 rockers sit so high compared to the frame rails.
        Edit: Starring at it on my large computer screen seems that it is a tad higher than it should be. Other than that it is pretty accurate to the end product, minus the trim badge, tinted windows, wipers (front and rear), and pig nose grills.
          Looking good sir, looking good! :D
            Pretty neat stuff Earl.
              All thanks to you=)
              Thank you bud
                Order placed with CA Tuned for my front brake lines and clutch line. I will also start assembling my calipers today hopefully=)
                  Springs coming quick - get going!!! ;)
                    I know. It blows
                    Just placed the ECS order yesterday for my front hubs and related bits, as well as all brand new hardware for the front suspension/steering and the chain tensioner cap with washer.
                    Once all that comes, I will be able to put together my front hub assemblies and get my motor together hopefully.
                    Greaser Kyle will be at the shop Saturday to do more work on the bay as well=)
                      Progress so far on the front subframe.
                      Picking up the reinforcement kit at break time and then possibly having it welded in sometime today or tomorrow=)
                        Did you get it from AKG?  For mine I had to pound in the piece that goes up inside with the holes, not sure if it's because my subframe was distorted when the mount ripped through, probably not bad to be so tight anyway.  Then the outside part with one big hole, weld the one side and pound it down to meet the engine mount ear, when finished the part has a compound curve and there is no way they would accurately manufacture it pre-bent.
                          I did get the AKG ones=) I'm not too worried. My subframe is actually in really good shape. That m42 torque must have been under control....haha
                            So akg is where it's at as far as reinforcements? I'm about to do mine. Not something I could just do myself eh? Well without spending too much time on it.
                              AKG has really good pricing compared to some of the others I have seen. I got mine because of their Cyber Monday sale=)
                              If you can weld, this is a super easy install. I can weld, but am too lazy and would rather have a welder at work do it for free.
                              Here is the install instructions for you sir: http://www.akgmotorsport.com/rfsp36install.html
                                AKG has the best price I have found, they seem to be permanently on sale, and the parts fit good.  I have some pics of the subframe ones and the rear sway reinforcements installed on my build thread if you want to see.  Very easy to weld in, I used my Hobart 110 flux core.
                                  I just checked it out. I'm not sure if I will actually need any of them... I will be reinforcing the front myself, and I 90% sure I will be tying my cage into the rear subframe... Hmmm.  And I won't be using a rear sway bar either. Yup. Nevermind guys!
                                    The AKG kit definitely requires a hammer to shape the outer piece=P lol
                                      Pretty sure all of the kits need to be bent after one side is welded, It sure beefs up the motor mount area doesn't it.
                                        Sure does lol
                                          Here is how far the welder got yesterday. Should be done today or Monday=)
                                          My CA Tuned front brake lines and clutch line came and they look great. I forgot to upload a picture to my photobucket though=/
                                          I assembled my calipers last night. All of them except for one went together great. There is one that I cannot get the piston past the o-ring and it is frustrating the hell out of me. I will be trying at it more today.
                                          Carrier bushings in
                                          Inner seal in
                                          All three that are done
                                          Here is how far the other front goes in
                                          I tried doing it all sorts of ways and then finally managed to get it stuck. I will hopefully figure it out but I know for sure the o-ring is the issue.
                                          Side note: one of the axles gave out on my daily as I pulled into work today so I am both unsure of how I am getting home, how I am getting to the shop tomorrow, and what I am going to do for a daily in general.
