    You are doing a great job on this Earl
      Thank you Brian=) Your approval makes it all worth it
        Looking good, and roll those fenders so you can tuck, and have this thing lay body!
          Not a huge fan of tuck. Also, I have the car sitting at the shop aired out on stock 15's and it is about 2"-3" away from laying frame. That is with nothing holding it up besides the bag being fully deflated. You would have to do a ton of fab work (customĀ trailing arms, modified upper mount, ect.)Ā to get it to lay frame in the back. I'll take a picture of it Wednesday=)
            Also, has anyone done rear wheel bearings on an e30? I need to do mine before this car becomes a daily again. They're absolutely horrid. I'm not sure how they got that bad. Didn't seem that bad when I took the trailing arms off initially.
              dang Earl, nice work!
                Looking good, and wheel bearings are easy. I'm pretty sure our very own J-stewart's replaced one!
                  Got something done I've been meaning too.
                  I finally got the hole cut properly to route my headlight harness back out of. Glad I had the right tools this time=) I also got the harness pulled through.
                  I also wrestled with the crank bolt for about an hour and still havent gotten it off. I figured the only way to lock it from turning is a wood block in between the crank and block. I didn't want to wrench too hard because I don't need a cracked block. I tried head. a deadblow, a 3 foot cheater bar and still it wouldn't budge.
                  How are you supposed to get this sucker off when the engine is on a stand? There has to be something I'm overlooking. I've tried a nice large electric impact and that did absolutely nothing besides make noise.
                  For those who were curious, here is a shot aired out on the 15's. This is with the bags fully compressed. To get lower would require pocketing the arms and frame. I won't be anywhere near this low so no worries for me=)
                  Also if you haven't noticed, the all reds are back on. I need to reclear the top of the drivers side and then I need to lay into them with a buffer to get them nice and shiny.
                  More to come Saturday
                  • merlM
                    merlM
                    merl
                    Your supposed to get the nut off with the engine in the car ... I made the same mistake. You need to hold the crank from moving and apply a lot of leverage and heat. I could not believe how tight the one on my car was. We had over a 4 foot bar and we were hanging off of it. I think the heat finally did the trick.
                      So do you recommend a way to do it while it is on the stand?
                      • merlM
                        merlM
                        merl
                        Well I was lucky enough to borrow the bmw tool and was able to wedge it against a steel cabinet. Then I heated the nut up for about 2 beers and laid on top of the engine while a 200 lb person hung off the cheater bar ... the noise it made was amazing...
                        If you have the flywheel on you can hold the crank from turning there but I am sure you don't have that on anymore ...
                        You need to build / buy one of theseĀ
                          ^This is good advice but I really think Earl just needs to eat red meat and man-up.
                            Now to find someone to borrow one of these suckers from. No one comes to mind though unfortunately=( This is truly frustrating.
                              Mine's held in with 370ft/tq, so yours is probably around the same. Best of luck getting that off without it in the car! =\
                              • merlM
                                merlM
                                merl
                                Where are you located Earl ?
                                ****325 lb ft from factory ... Pretty sure mine took over 1000 to get off.
                                  ^Exactly. It'll tighten/seize up over the years.
                                    I live in West Bend, but the shop is located off of Good Hope. It's right across the road from the Ruby Tuesdays.
                                    • merlM
                                      merlM
                                      merl
                                      I want to help you but I am a bit tight on time since I am taking the day off tomorrow to assemble the core of my engine and continuing through the weekend for installation. I am not sure when I could get there ..Ā  :(
                                        have earl pick it up! 😧
                                        • merlM
                                          merlM
                                          merl
                                          I don't own the tool so I would need to go with it. Not anything to do with trust, just my rule. Plus, I will prob need it for install.
