    I am very pleased with the outcome of Saturday=)
    I finally got the top of my bags mounted. The first side took two hours....the second side only took about 30-45 minutes. Here is what I did (before paint of course)
    There is one bolt up top and then a notch underneath for the fitting to sit in. The pockets were the biggest pain to get. The first one took so long because I was trying to use a countersink bit and other drill bits. Then I realized I had air tools that would make it a whole lot easier=)
    Once that was finally out of the way, I bolted up my sway bar and bolted the bottom of the mustang shocks to the trailing arms. Everything went super smooth there.
    I then installed my 68mm Motorsport Hardware studs. I am super happy with the quality of them. Installation was a breeze and I highly recommend them to anyone who wants to go studs versus lug bolts. The price tag for these is basically just giving them away=D
    I also painted the hats of my rear rotors during this time, but did not take a picture. I will be getting new rotors this winter, so this is just to make them look less shitty until then.
    After all of this I cut air line for the bags, pushed on some valve stem fittings, and manually aired up the bags. I put the rear wheels on and put it back on all fours for the first time since February. I then aired it out.
    I was being goofy. I actually have to do way less fender work than I had initially thought. That's fine by me=) I just need to get the fenders over the tire, but let the lip still poke. Right now it is literally sitting on the tire. Here are a few more of the wheels and being aired out on the Breytons.
    I am finally seeing things come together and it is awesome=) The studs poke a tiny bit much for me, but they were the shortest I could get being black and bullet nosed. I think they will still keep the clean and subtle look without being too aggressive.
    On a side note, my friend Kerry has been working on my rear bumper and I cannot thank him enough. I wanted the exhaust cutout shaved so I can have the exhaust hidden underneath. I am not a huge fan of DTM tips and this was the cleanest option I could come up with. I also don't really like the M-Tech rear bumper so I figured I would make the OEM one better.
    He did such an excellent job. He used no bondo and uses only the finest plastic repair kits. Bravo Kerry=)
    More to come Wednesday. Maybe I will take a funny picture of how the rear is sitting right now aired out on stock wheels.
      You are doing a great job on this Earl
        Thank you Brian=) Your approval makes it all worth it
          Looking good, and roll those fenders so you can tuck, and have this thing lay body!
            Not a huge fan of tuck. Also, I have the car sitting at the shop aired out on stock 15's and it is about 2"-3" away from laying frame. That is with nothing holding it up besides the bag being fully deflated. You would have to do a ton of fab work (customĀ trailing arms, modified upper mount, ect.)Ā to get it to lay frame in the back. I'll take a picture of it Wednesday=)
              Also, has anyone done rear wheel bearings on an e30? I need to do mine before this car becomes a daily again. They're absolutely horrid. I'm not sure how they got that bad. Didn't seem that bad when I took the trailing arms off initially.
                dang Earl, nice work!
                  Looking good, and wheel bearings are easy. I'm pretty sure our very own J-stewart's replaced one!
                    Got something done I've been meaning too.
                    I finally got the hole cut properly to route my headlight harness back out of. Glad I had the right tools this time=) I also got the harness pulled through.
                    I also wrestled with the crank bolt for about an hour and still havent gotten it off. I figured the only way to lock it from turning is a wood block in between the crank and block. I didn't want to wrench too hard because I don't need a cracked block. I tried head. a deadblow, a 3 foot cheater bar and still it wouldn't budge.
                    How are you supposed to get this sucker off when the engine is on a stand? There has to be something I'm overlooking. I've tried a nice large electric impact and that did absolutely nothing besides make noise.
                    For those who were curious, here is a shot aired out on the 15's. This is with the bags fully compressed. To get lower would require pocketing the arms and frame. I won't be anywhere near this low so no worries for me=)
                    Also if you haven't noticed, the all reds are back on. I need to reclear the top of the drivers side and then I need to lay into them with a buffer to get them nice and shiny.
                    More to come Saturday
                    • merlM
                      merlM
                      merl
                      Your supposed to get the nut off with the engine in the car ... I made the same mistake. You need to hold the crank from moving and apply a lot of leverage and heat. I could not believe how tight the one on my car was. We had over a 4 foot bar and we were hanging off of it. I think the heat finally did the trick.
                        So do you recommend a way to do it while it is on the stand?
                        • merlM
                          merlM
                          merl
                          Well I was lucky enough to borrow the bmw tool and was able to wedge it against a steel cabinet. Then I heated the nut up for about 2 beers and laid on top of the engine while a 200 lb person hung off the cheater bar ... the noise it made was amazing...
                          If you have the flywheel on you can hold the crank from turning there but I am sure you don't have that on anymore ...
                          You need to build / buy one of theseĀ
                            ^This is good advice but I really think Earl just needs to eat red meat and man-up.
                              Now to find someone to borrow one of these suckers from. No one comes to mind though unfortunately=( This is truly frustrating.
                                Mine's held in with 370ft/tq, so yours is probably around the same. Best of luck getting that off without it in the car! =\
                                • merlM
                                  merlM
                                  merl
                                  Where are you located Earl ?
                                  ****325 lb ft from factory ... Pretty sure mine took over 1000 to get off.
                                    ^Exactly. It'll tighten/seize up over the years.
                                      I live in West Bend, but the shop is located off of Good Hope. It's right across the road from the Ruby Tuesdays.
                                      • merlM
                                        merlM
                                        merl
                                        I want to help you but I am a bit tight on time since I am taking the day off tomorrow to assemble the core of my engine and continuing through the weekend for installation. I am not sure when I could get there ..Ā  :(
                                          have earl pick it up! 😧
