  4. The Dirty Dolphin build thread
delphine30325icoupe
74 Posts 19 Posters 1.6k Views 1 Watching
  • AndrewA
    AndrewA
    Andrew
    I had a flat tire today (screw in tire) and while the wheel was off i took a peek a the status of the rear brake pads.  Is that a large amount of piston to be extending out of the caliper???  Almost worn down to the backing plate on the sensor side.aprildump109.jpg
    This next pic is to orient you for the third pic
    I've got gas leaking from what i think is the top of the gas tank (only badly when it is full).  Is this a normal spot for a leak?  What do you suspect is the issue?
    Also, what is this nasty thing below referred to as (i think it covers the battery cable)?  I have a strange urge to try to make a new one out of carbon fiber... because America... and i've always wanted to make something out of carbon.
      Here is the cover, You may be able to find it elsewhere for a bit cheaper but the part number is in there. I believe it is covering the fuel return line or evap hose.
      [http://www.turnermotorsport.com/p-7378-16131179011-genuine-bmw-part.aspx
      H](http://www.turnermotorsport.com/p-7378-16131179011-genuine-bmw-part.aspx)ere is a picture of the top of the fuel tank, there are some lines there, but I have never had to work with the fuel tank so I am not sure what areas may be leak prone
      • mystere30M
        mystere30M
        mystere30
        that is a common spot for a leak on the gas tank. its probably from the top of the tank. mine did the same thing. i also believe ben's did the same thing. and being me...i just never filled past half tank instead of actually fixing it lol.
        • M
          M
          Mott Power
          Damn!  You were the one that beat me to that car!  Haha - can't wait to see this progress.
            too bad about the nail in the tire :( I'm excited about this build thread! Get yourself a bentley e30 repair guide if you don't have one. They call them bibles for a reason  ;)
            • AndrewA
              AndrewA
              Andrew
              It's good to know there is an easy solution :D
              I'm pretty sure i didn't sell the one I bought when i had my last E30; I knew I would ride in God's chariot again!  Now where did I put it...
              Also, I just ordered Brembo blanks, Axxis ultimate pads, and caliper rebuild kits for all corners.  Bought Turner front subframe reinforcements as well (currently accepting offers for welding assistance).  Need to find a good vendor for a remanufactured Z3 rack next.  This could escalate quickly...
                Rock Auto has a reman for $255 with no core charge. I would be more inclined to find one without a core charge since I can imagine some drama with returning a different core. I had to really sweet talk the driveshaft shop into letting me return an automatic driveshaft for a manual driveshaft when I did my 5spd swap.
                Did you order up some new soft lines?
                  Chadley is your man!
                  • Ryan...R
                    Ryan...R
                    Ryan...
                    Is this my/applesauce's former car?
                      Yessir
                      • Ryan...R
                        Ryan...R
                        Ryan...
                        Nice, glad to see it getting some more lovin!
                          Love the Ayrton Senna avatar. I wish he was still around to give Vettel a run for his money.
                            Good to see the car getting what it deserves.  Also, when those lights finally show up, I have some extra fun stuff for you.  I guess I don't really need my M20 powder coated valve cover so....
                            • AndrewA
                              AndrewA
                              Andrew
                              Funny you should mention the valve cover, since i just purchased a valve cover gasket in preparation for refinishing the one on the car.  Also, brake parts arrived...  Who wants to have a brake job party :)
                                Andrew said:
                                Funny you should mention the valve cover, since i just purchased a valve cover gasket in preparation for refinishing the one on the car.  Also, brake parts arrived...  Who wants to have a break job party :)
                                A BJ party??
                                • AndrewA
                                  AndrewA
                                  Andrew
                                  A BJ party??
                                  Yes, a BJ party; BJ's for everyone.
                                  So this is what a subframe looks like, 50 lbs of coal slag later.  Note to self: just clean future subrames up enough to weld on reinforcement plates and be done with it.  Now, what color do i powdercoat it...  I kind of like the silver color it is now.  A slate blue?  Eau de nil?  Zinc Phospate primer?  Black is so 1989.
                                    Andrew just gave me the opportunity to drive this car.
                                    It was so manly, that I grew a third ball.
                                      Abouts like this?
                                        ^Amazing!  hahah!!!
                                        and for the sake of remaining on topic, I need some Axxis Ultimates. they are much better than my Axxis XBGs
                                        • AndrewA
                                          AndrewA
                                          Andrew
                                          So today I was planning on securing the loose strut collar nut that Snap helped me discover, cept I'm not sure how im going to get the shock cartridge down into the strut body ( the picture below was taken with the corner in the air aka full droop). Any ideas?  The picture shows, from top to bottom, the strut collar nut, the top of the Bilstein shock, and the top of the strut housing.  The shock should be entirely inside the strut housing, and should be captured by the collar nut.
                                           Also, I have sandblasted the wheels that were "time attacked" and reinstalled them on the car (pics eventually)  I really like the raw blasted aluminum look, and will likely throw a clear coat on them.
