  4. The Dirty Dolphin build thread
delphine30325icoupe
74 Posts 19 Posters 1.6k Views 1 Watching
  • Ryan...R
    Ryan...R
    Ryan...
    Nice, glad to see it getting some more lovin!
      Love the Ayrton Senna avatar. I wish he was still around to give Vettel a run for his money.
        Good to see the car getting what it deserves.  Also, when those lights finally show up, I have some extra fun stuff for you.  I guess I don't really need my M20 powder coated valve cover so....
        • AndrewA
          AndrewA
          Andrew
          Funny you should mention the valve cover, since i just purchased a valve cover gasket in preparation for refinishing the one on the car.  Also, brake parts arrived...  Who wants to have a brake job party :)
            Andrew said:
            Funny you should mention the valve cover, since i just purchased a valve cover gasket in preparation for refinishing the one on the car.  Also, brake parts arrived...  Who wants to have a break job party :)
            A BJ party??
            • AndrewA
              AndrewA
              Andrew
              A BJ party??
              Yes, a BJ party; BJ's for everyone.
              So this is what a subframe looks like, 50 lbs of coal slag later.  Note to self: just clean future subrames up enough to weld on reinforcement plates and be done with it.  Now, what color do i powdercoat it...  I kind of like the silver color it is now.  A slate blue?  Eau de nil?  Zinc Phospate primer?  Black is so 1989.
                Andrew just gave me the opportunity to drive this car.
                It was so manly, that I grew a third ball.
                  Abouts like this?
                    ^Amazing!  hahah!!!
                    and for the sake of remaining on topic, I need some Axxis Ultimates. they are much better than my Axxis XBGs
                    • AndrewA
                      AndrewA
                      Andrew
                      So today I was planning on securing the loose strut collar nut that Snap helped me discover, cept I'm not sure how im going to get the shock cartridge down into the strut body ( the picture below was taken with the corner in the air aka full droop). Any ideas?  The picture shows, from top to bottom, the strut collar nut, the top of the Bilstein shock, and the top of the strut housing.  The shock should be entirely inside the strut housing, and should be captured by the collar nut.
                       Also, I have sandblasted the wheels that were "time attacked" and reinstalled them on the car (pics eventually)  I really like the raw blasted aluminum look, and will likely throw a clear coat on them.
                        You are going to have to remove the strut from the car, remove the spring, then tap the strut insert down into place by striking the top of the gland nut. If the insert comes out nicely by hand, you may want to check to make sure the oil in the bottom of the strut housing has been removed. (Nitrogen filled struts do not require oil in the bottom of the housing).  If you really dont want to remove the strut from the car then I may have some alternative ideas.
                          I has m3 rack if you are interested
                          • AndrewA
                            AndrewA
                            Andrew
                            http://s471.photobucket.com/user/inline39/media/The%20Dirty%20Dolphin/IMG_0570.mp4.html
                            Time for new front shocks... and control arms... and how much play should there be in the shock mount bearing?
                            • AndrewA
                              AndrewA
                              Andrew
                              Nasty nasty Bilsteins.  What should i replace them with?  Bilstein Sports or Koni Yellows?
                                Having had both, I would go with koni's.
                                  Koni's for sure. Bisteins are alright, but for upgrades, I'd definitely go with Koni. Go adjustable
                                  • AndrewA
                                    AndrewA
                                    Andrew
                                    She's back on her feet with a freshly tightened strut collar nut.  No more big clunks, but it still crashes over bumps more than i think it should. Below is a pic of the raw sandblasted bottlecaps which used to be time attacked.  Now I need to source a Z3 rack for the next big project phase which includes the z3 rack, replacing the current damaged front subframe with a reinforced and freshly powdercoated one, and brand new control arms.  I may throw new shock cartridges in while i'm at it but i haven't decided yet.  I discovered that the poop covered damper (pictured in the previous posts) is not completely blown like i thought.
                                    • AndrewA
                                      AndrewA
                                      Andrew
                                      An update on the glacial progress of the car.  The cardinal interior is in (it has been for a while).  Someone sell me some cardinal sport seats!  And my spare subframe has been improved. Can you spot the upgrade?  Also, has anyone purchased a steering rack from the rack doctor?
                                        ugh, that subframe looks incredible.
                                        Now you need some extra HP to put the engine mount reinforcements to good use  O__O
                                          Second on the subframe, looks awesome! Is that powder coated?
                                          As far as the seats, I know your driver seat needs a rebuild. If you'd be willing to fix it yourself you could then just recover the seats too. When I plan to build a set of hybrid e30/e28 sport seats I'm gonna use kits from this seller. http://www.ebay.com/usr/zoomzoomzoom-ing They have good reviews from guys on other forums that have used them and the prices are decent too.
