  4. Electric Fan
Electric Fan
42 Posts 12 Posters 696 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    merl said:
    Thank you sir !
    the fan set up works great in my car never went past the middle on my car. even when rage driving.
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • merlM
      merlM
      merl
      merl said:
      Brian, I just ordered the tool for the fan and can help you get that off.
      These radiators really lose a lot of flow when they age. I never overheated in day to day driving but the car was HOT on the track. A new radiator is being ordered as part of this build.
      When new, the rads work very good and they are only about 175 bucks new.
      I think I should have said new a few more times in this post  :rolleyes:
      • JeffJ
        JeffJ
        Jeff
        yea just rub them new parts in why dont you.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • merlM
          merlM
          merl
          Ha ! ... I didn't mean it that way .. I was pointing out my awful grammar ...
          Jeff, that sensor goes in the rad where the aux fan temp sensors were ?? Am I thinking of that correctly ??
          • JeffJ
            JeffJ
            Jeff
            yes in the radiator where the aux fan sensor goes. take the sensor out go to lowes or napa and get the adaptor so you can thred it in the radiator. the sensor is 1/8npt thred.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • merlM
              merlM
              merl
              Nice ...
              Thanks a ton.
                I have a brand new radiator in the 535I. still warms up. I got my radiator for $100 shipped. Autopartswarehouse= direct fit, not a single problem. rad showed up, no fins bent, nothin.
                Jeff said:
                bring the car to my house and i will remove it!
                Come to my house with the truck!
                • JeffJ
                  JeffJ
                  Jeff
                  it will run out of gas by the time i make it there
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    insinuating my maybe soon to be truck has a gas leak? or is just that god awful on gas?
                    • JeffJ
                      JeffJ
                      Jeff
                      15 on the highway
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Jeff said:
                        15 on the highway
                        I think you're speeding
                        • JeffJ
                          JeffJ
                          Jeff
                          No sir only 70
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            bimmer82
                            I have a 16" slim fit spal puller on my e30 with the relay kit from bimmerworld if you need any more advice.. wired it up to the AC temp switch on radiator so that it kicks on right when the coolant needle passes half way..
                              I ran a 16" pusher in front of my m20 radiator with the m50 swap, rarely need to use it But its a great thing to have in case.
                              Would have ran it as a puller, but it wouldn't fit between the radiator and the motor..... Lol.
                                I'm using this switch BMW# 61318361787  and just took out the mech fan.  It's 80/88 degree C instead of 91/99 C.  Only comes on low speed occasionally when idling for a long time in hot weather.  Easy and only need to buy the different switch.
                                Edit: I should clarify, mostly stock M50 with 88c thermostat.  Usually runs about 195 - 200 F on autometer gauge at factory sender location in head.  Never seen it above 210 even idling in very hot weather.
                                • merlM
                                  merlM
                                  merl
                                  So I ended up ordering a reversible fan and did end up having to mount it as a pusher but that also means I can spin the mechanical fan on if needed. Thanks for the help on this guys.
                                  • RamRod E28R
                                    RamRod E28R
                                    RamRod E28
                                    Brian just get an air hammer with a long ass punch on it.... Works like a charm and I need to do something with my e28s cooling fan as well
                                    1988 BMW 528e - Need parts?
                                    1996 Mazda Miata (SOLD!!!)
                                    1996 BMW 325i (Donor car)
                                      I've no idea what you're referring to. I'm gunna take a blind shot in the dark, an say it's referring to cooling fan clutch bolt? I got that out ages ago. I'll be running a bigger radiator (griffin raditator) That'll be pushed further forward into the front rad. support. So I'll have PLENTY of room for a puller fan, or 2 and a custom shroud.
                                      • CMartC
                                        CMartC
                                        CMart
                                        Bump to this old thread.
                                        Any tips on removing the clutch fan or does anyone local to Milwaukee have the tool I can borrow?
                                        Excursion 7.3
                                        E30 LS1
                                          I used the claw end of a hammer to hold it in place... it was also -15 in January when my fan deleted itself and I needed to replace my water pump and radiator.  You can also keep the accessory belt wrapped around the fan clutch and hold it tight then undo the bolt.  That works sometimes as well.
                                          Or spend $20 on the tool.
