  4. Electric Fan
Electric Fan
42 Posts 12 Posters 0 Views 1 Watching
    Jeff said:
    15 on the highway
    I think you're speeding
    • JeffJ
      JeffJ
      Jeff
      No sir only 70
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        bimmer82
        I have a 16" slim fit spal puller on my e30 with the relay kit from bimmerworld if you need any more advice.. wired it up to the AC temp switch on radiator so that it kicks on right when the coolant needle passes half way..
          I ran a 16" pusher in front of my m20 radiator with the m50 swap, rarely need to use it But its a great thing to have in case.
          Would have ran it as a puller, but it wouldn't fit between the radiator and the motor..... Lol.
            I'm using this switch BMW# 61318361787  and just took out the mech fan.  It's 80/88 degree C instead of 91/99 C.  Only comes on low speed occasionally when idling for a long time in hot weather.  Easy and only need to buy the different switch.
            Edit: I should clarify, mostly stock M50 with 88c thermostat.  Usually runs about 195 - 200 F on autometer gauge at factory sender location in head.  Never seen it above 210 even idling in very hot weather.
            • merlM
              merlM
              merl
              So I ended up ordering a reversible fan and did end up having to mount it as a pusher but that also means I can spin the mechanical fan on if needed. Thanks for the help on this guys.
              • RamRod E28R
                RamRod E28R
                RamRod E28
                Brian just get an air hammer with a long ass punch on it.... Works like a charm and I need to do something with my e28s cooling fan as well
                1988 BMW 528e - Need parts?
                1996 Mazda Miata (SOLD!!!)
                1996 BMW 325i (Donor car)
                  I've no idea what you're referring to. I'm gunna take a blind shot in the dark, an say it's referring to cooling fan clutch bolt? I got that out ages ago. I'll be running a bigger radiator (griffin raditator) That'll be pushed further forward into the front rad. support. So I'll have PLENTY of room for a puller fan, or 2 and a custom shroud.
                  • CMartC
                    CMartC
                    CMart
                    Bump to this old thread.
                    Any tips on removing the clutch fan or does anyone local to Milwaukee have the tool I can borrow?
                    Excursion 7.3
                    E30 LS1
                      I used the claw end of a hammer to hold it in place... it was also -15 in January when my fan deleted itself and I needed to replace my water pump and radiator.  You can also keep the accessory belt wrapped around the fan clutch and hold it tight then undo the bolt.  That works sometimes as well.
                      Or spend $20 on the tool.
                      • CMartC
                        CMartC
                        CMart
                        I like the claw hammer idea.
                        These are reverse thread correct?
                        Excursion 7.3
                        E30 LS1
                          Glad to see you back!
                            Correct.  I tried holding the pulley with everything I could think of from screwdriver, pry bar, crow bar, etc and actually bent one of the screws holding the pulley on with the pry bar.  I took a small claw hammer that I had and wedged the claw end in and voila!  Nut was off.
