  4. Electric Fan
Electric Fan
42 Posts 12 Posters 696 Views 1 Watching
    merl said:
    Jeff, Do you have a link to what sensor you used ?
    Brian, thanks a ton. I think I am going to start with a pusher but if there are issues, I will move it to puller.
    My pusher works really well, but in summer (like last summer, my car over heated ALOT. 90+ all summer... I wanna switch to puller. but my damn clutch fan won't release.
    • merlM
      merlM
      merl
      Brian, I just ordered the tool for the fan and can help you get that off.
      These radiators really lose a lot of flow when they age. I never overheated in day to day driving but the car was HOT on the track. A new radiator is being ordered as part of this build.
      When new, the rads work very good and they are only about 175 bucks new.
      • JeffJ
        JeffJ
        Jeff
        bring the car to my house and i will remove it!
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          merl said:
          Thank you sir !
          the fan set up works great in my car never went past the middle on my car. even when rage driving.
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
          • merlM
            merlM
            merl
            I think I should have said new a few more times in this post  :rolleyes:
            • JeffJ
              JeffJ
              Jeff
              yea just rub them new parts in why dont you.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • merlM
                merlM
                merl
                Ha ! ... I didn't mean it that way .. I was pointing out my awful grammar ...
                Jeff, that sensor goes in the rad where the aux fan temp sensors were ?? Am I thinking of that correctly ??
                • JeffJ
                  JeffJ
                  Jeff
                  yes in the radiator where the aux fan sensor goes. take the sensor out go to lowes or napa and get the adaptor so you can thred it in the radiator. the sensor is 1/8npt thred.
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                  • merlM
                    merlM
                    merl
                    Nice ...
                    Thanks a ton.
                      I have a brand new radiator in the 535I. still warms up. I got my radiator for $100 shipped. Autopartswarehouse= direct fit, not a single problem. rad showed up, no fins bent, nothin.
                      Come to my house with the truck!
                      • JeffJ
                        JeffJ
                        Jeff
                        it will run out of gas by the time i make it there
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          insinuating my maybe soon to be truck has a gas leak? or is just that god awful on gas?
                          • JeffJ
                            JeffJ
                            Jeff
                            15 on the highway
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              Jeff said:
                              15 on the highway
                              I think you're speeding
                              • JeffJ
                                JeffJ
                                Jeff
                                No sir only 70
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  bimmer82
                                  I have a 16" slim fit spal puller on my e30 with the relay kit from bimmerworld if you need any more advice.. wired it up to the AC temp switch on radiator so that it kicks on right when the coolant needle passes half way..
                                    I ran a 16" pusher in front of my m20 radiator with the m50 swap, rarely need to use it But its a great thing to have in case.
                                    Would have ran it as a puller, but it wouldn't fit between the radiator and the motor..... Lol.
                                      I'm using this switch BMW# 61318361787  and just took out the mech fan.  It's 80/88 degree C instead of 91/99 C.  Only comes on low speed occasionally when idling for a long time in hot weather.  Easy and only need to buy the different switch.
                                      Edit: I should clarify, mostly stock M50 with 88c thermostat.  Usually runs about 195 - 200 F on autometer gauge at factory sender location in head.  Never seen it above 210 even idling in very hot weather.
                                      • merlM
                                        merlM
                                        merl
                                        So I ended up ordering a reversible fan and did end up having to mount it as a pusher but that also means I can spin the mechanical fan on if needed. Thanks for the help on this guys.
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          Brian just get an air hammer with a long ass punch on it.... Works like a charm and I need to do something with my e28s cooling fan as well
                                          1988 BMW 528e - Need parts?
                                          1996 Mazda Miata (SOLD!!!)
                                          1996 BMW 325i (Donor car)
