    Rowleym said:
    Well if I already have a 255, I'm going to install it. So should I run another 255 inline or something?
    Rustowleyum, Hi.
    Posted Image
    Dont go lean.
    That is all.
    bye!!! 1
      Snap Understeer said:
      Rustowleyum, Hi.
      Posted Image
      Dont go lean.
      That is all.
      bye!!! 1
      Kashi takes like recycled cardboard.
        ^lol. Haven't tasted it. Yes. I'm trying not to go lean! Also. How much 4an steel braided line should I buy? I need it for turbo feed, and all new fuel lines.
          Blaine0002
          Rowleym said:
          Why wouldn't I? I don't need to lower the compression at all.
          m50 headgaskets are notorious for blowing without boost at all.
            I'm looking for 350-400wheel, and this motor normally support 350 without arp's even. I think I should be able to manage. If I blow it, oh well. It's like a boost fuse haha. Too much boost and bad tuning, I blow a hg versus a piston haha.
              ha! I like that.
              Better than blowing the welds on your intake manifold for sure!!!!!!!!!!!!
              p.s. !!!!!!!!!!!!!!
                To be honest, on a car like this where its not my dd, it's kind of okay when things break. It makes you upgrade for the best! No better way to get motivation to get forged internals than blowing the shit out of your block.
                • 240sxguy2
                  240sxguy2
                  240sxguy
                  Install it and tune, you will find out if that pump is a bottleneck or not.
                  -4 is WAY too small for fuel lines. -6 minimum.
                    Alright for sure. Would you just run rubber lines? Like those high pressure efi ones? Or would you do braided? Also, do you think i need a new fuel rail? This fuel thing is really getting me.
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      It's common practice in the turbo volvo world to run a factory head gasket and treat it like a fuse. Those who go the MLS Cometic approach (without a lot of time spent tuning on the dyno by a professional) often live to regret that decision.
                        Go braided. Looks better. And the fuel rail, factory fuel rail *should* be fine. Just upgrade injectors/possibly get a higher bar FPR.
                          Blaine0002
                          Maybe, I went Cometic to get a lower CR.
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            The kool-aid man prefers Cometic gaskets 9 times out of 10.
                              You seem to be the expert on this subject so I have a question for you. Can the kool-aid man bust through a wall made of Cometic gaskets?
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                OH YEAAAAAAAAAAAAH
                                http://www.dxpnet.com/i.asp?f=http://www.icanhasinternets.com/wp-content/uploads/2010/07/Kool-AidMan.jpeg
                                :D
                                To clarify: There is nothing wrong with cometic gaskets at all. They are great, but for a lot of people, they just aren't necessarily the best choice.
                                  lol , well played
                                    Why would they not be the best decision?
                                    People not understanding that a motor can only take so much boost?
                                      Yea but its kind of cheating when using a Mls to lower compression. A lot of the time people run them and think they can turn the boost up real high, and then they end up blowing it up because they don't have a proper tune. Proper tune and you are good to go! It's a great way to use pump gas. I'm quite stoked about this e85 thing. Absolutely no need for me to lower compression :D
                                        It doesn't matter to me if it looks good, I was just wondering if the rubber stuff performs as well. The 80# injectors will already be more than enough, I just need the rest of the fuel system to handle it!
                                          It's not cause they look good, although they do. braided lines perform better. and have less chance of kinking. and can hold higher pressure/temp.
