    To be honest, on a car like this where its not my dd, it's kind of okay when things break. It makes you upgrade for the best! No better way to get motivation to get forged internals than blowing the shit out of your block.
    • 240sxguy2
      240sxguy2
      240sxguy
      Install it and tune, you will find out if that pump is a bottleneck or not.
      -4 is WAY too small for fuel lines. -6 minimum.
        Alright for sure. Would you just run rubber lines? Like those high pressure efi ones? Or would you do braided? Also, do you think i need a new fuel rail? This fuel thing is really getting me.
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Rowleym said:
          I'm looking for 350-400wheel, and this motor normally support 350 without arp's even. I think I should be able to manage. If I blow it, oh well. It's like a boost fuse haha. Too much boost and bad tuning, I blow a hg versus a piston haha.
          It's common practice in the turbo volvo world to run a factory head gasket and treat it like a fuse. Those who go the MLS Cometic approach (without a lot of time spent tuning on the dyno by a professional) often live to regret that decision.
            Go braided. Looks better. And the fuel rail, factory fuel rail *should* be fine. Just upgrade injectors/possibly get a higher bar FPR.
              Blaine0002
              Maybe, I went Cometic to get a lower CR.
              • The Full BananaT
                The Full BananaT
                The Full Banana
                The kool-aid man prefers Cometic gaskets 9 times out of 10.
                  You seem to be the expert on this subject so I have a question for you. Can the kool-aid man bust through a wall made of Cometic gaskets?
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    OH YEAAAAAAAAAAAAH
                    http://www.dxpnet.com/i.asp?f=http://www.icanhasinternets.com/wp-content/uploads/2010/07/Kool-AidMan.jpeg
                    :D
                    To clarify: There is nothing wrong with cometic gaskets at all. They are great, but for a lot of people, they just aren't necessarily the best choice.
                      lol , well played
                        Why would they not be the best decision?
                        People not understanding that a motor can only take so much boost?
                          Yea but its kind of cheating when using a Mls to lower compression. A lot of the time people run them and think they can turn the boost up real high, and then they end up blowing it up because they don't have a proper tune. Proper tune and you are good to go! It's a great way to use pump gas. I'm quite stoked about this e85 thing. Absolutely no need for me to lower compression :D
                            It doesn't matter to me if it looks good, I was just wondering if the rubber stuff performs as well. The 80# injectors will already be more than enough, I just need the rest of the fuel system to handle it!
                              It's not cause they look good, although they do. braided lines perform better. and have less chance of kinking. and can hold higher pressure/temp.
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                This.
                                which is why I say that it's often a better choice for people to run a factory gasket if they are doing their own tuning and don't have either a lot of experience or a dyno.
                                  Blaine0002
                                  This.
                                  I guess i assumed that people wanted to do the job right 😕
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    It's a lot cheaper to pop a gasket than to melt a piston or put a big hole in the side of the block.
                                      Blaine0002
                                      Then dont do that :o
                                        Blaine0002
                                        and if you're talking about boosting, you probably shouldn't even include the word cheap in the sentence anyways.
                                          Haha. Right? ^
