  4. ‘91 E30
‘91 E30
    Surprised you didn't go with a cool m cloth or something! I like the minimalist look though!
      I like those styles more when they’re in someone else’s car lol
        paint looks great and i really like how the boots match your seats/dash
          The dash mat is most excellent
            +1
            Where is it from? Want to try and preserve my crack free dash.
              https://www.covercraft.com/us/en/shop/bmw/dash-covers/
                Ordered a black suede one.
                Made to order, estimated ship in 45 business days 🥴
                  ChaseBays power steering stuff showed up today which was semi exciting.
                  that’s threaded all the way in, I’ll just need 12 crush washers 🙄🙄🙄🙄🙄
                  hoping I hear back from them soon so I can get the right stuff
                    Weird, I have the same chase bays pressure line and likely the same power steering pump. Nothing stuck in the pump threads?
                      Nope
                        Nope
                        That sucks... hopefully they can get you the right fitting asap!
                          I was kind of expecting an issue tbh, in the meantime I’m going to cut this one down so I can at least go drive the car around.
                            You are better off using spacers. That bevel helps seal it
                              It’s not really beveled in a way that works with an -an fitting, I’m not even sure the bevel is there to aid with sealing because stock was sealed with crush washers & the banjo bolts that thread into that dont have a bevel on them to my knowledge either
                                No, it seals with a crush washer.
                                  They asked for pics, said they have a fitting with a rubber oring that rests against the flange thing  in my photos above (Flange in the threaded portion)
                                  cant wait for that to spring a high psi leak
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Also, is that an aluminum fitting on the high pressure line? I wouldn't trust if so, even if it did fit. I've seen aluminum fittings fail in that application. Steel all the way for high-pressure hydraulic lines.
                                      It sure is. We’ll see how long the chasebays stuff lasts I guess
                                        theyve been selling it for years. if there were some great amount of failures, shoudnt we have heard about it by now? i think they use some aluminum fittings for the brake stuff, even. cant muck about with brakes with inferior stuffs and not have a lawsuit.
                                          Chase Bays... More like Wait for days!  Ok I'm done.
