  4. ‘91 E30
‘91 E30
    Switched to poly exhaust hangars to eliminate the side to side play which led to some annoying noises. Think I fixed the random brake fluid light that pops on the dash, if not I’ll be ordering a new cap. Also installed the wheel/spacer. The momo mod69 wheel has good girth and has basically zero flex which is what I was after. 49DAC619-6AF1-47B9-8F0D-EAAB862A009B.jpeg
    I tightened up the heater core hoses a bit, we will see if that fixes the drip
      ne'er a better "thats what she said" setup has been spoken.
        I basically set that one on the tee for you
          gf finished up the car today. She wasn’t too happy with it because the paint was very soft/picky, I think it turned out great for 30yo paint.  IMG_5941.mov
            Rolled it out into the sun today to check out her work 😎
              Wow!  She did a great job!  Let Henry roll around on the hood for the final polish maybe.
                Ditched the accordion ebrake boot and the shift boot for some suede bits.  fixed the ebrake wiring for the dash light as well  907BE5AB-AEDB-4774-B8B0-884667841933.jpeg
                also removed the PS. It has been leaking like crazy lately. Ditching OEM stuff and going with -an stuff and braided lines which should show up in a few days3E04B569-68FB-4E63-A6A4-95956F993481.jpeg
                Changed the oil too.
                  Surprised you didn't go with a cool m cloth or something! I like the minimalist look though!
                    I like those styles more when they’re in someone else’s car lol
                      paint looks great and i really like how the boots match your seats/dash
                        The dash mat is most excellent
                          +1
                          Where is it from? Want to try and preserve my crack free dash.
                            https://www.covercraft.com/us/en/shop/bmw/dash-covers/
                              Ordered a black suede one.
                              Made to order, estimated ship in 45 business days 🥴
                                ChaseBays power steering stuff showed up today which was semi exciting.
                                that’s threaded all the way in, I’ll just need 12 crush washers 🙄🙄🙄🙄🙄
                                hoping I hear back from them soon so I can get the right stuff
                                  Weird, I have the same chase bays pressure line and likely the same power steering pump. Nothing stuck in the pump threads?
                                    Nope
                                      Nope
                                      That sucks... hopefully they can get you the right fitting asap!
                                        I was kind of expecting an issue tbh, in the meantime I’m going to cut this one down so I can at least go drive the car around.
                                          You are better off using spacers. That bevel helps seal it
