  4. ‘91 E30
‘91 E30
    The dash mat is most excellent
    +1
    Where is it from? Want to try and preserve my crack free dash.
      https://www.covercraft.com/us/en/shop/bmw/dash-covers/
        Ordered a black suede one.
        Made to order, estimated ship in 45 business days 🥴
          ChaseBays power steering stuff showed up today which was semi exciting.
          that’s threaded all the way in, I’ll just need 12 crush washers 🙄🙄🙄🙄🙄
          hoping I hear back from them soon so I can get the right stuff
            Weird, I have the same chase bays pressure line and likely the same power steering pump. Nothing stuck in the pump threads?
              Nope
                Nope
                That sucks... hopefully they can get you the right fitting asap!
                  I was kind of expecting an issue tbh, in the meantime I’m going to cut this one down so I can at least go drive the car around.
                    You are better off using spacers. That bevel helps seal it
                      It’s not really beveled in a way that works with an -an fitting, I’m not even sure the bevel is there to aid with sealing because stock was sealed with crush washers & the banjo bolts that thread into that dont have a bevel on them to my knowledge either
                        No, it seals with a crush washer.
                          They asked for pics, said they have a fitting with a rubber oring that rests against the flange thing  in my photos above (Flange in the threaded portion)
                          cant wait for that to spring a high psi leak
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Also, is that an aluminum fitting on the high pressure line? I wouldn't trust if so, even if it did fit. I've seen aluminum fittings fail in that application. Steel all the way for high-pressure hydraulic lines.
                              It sure is. We’ll see how long the chasebays stuff lasts I guess
                                theyve been selling it for years. if there were some great amount of failures, shoudnt we have heard about it by now? i think they use some aluminum fittings for the brake stuff, even. cant muck about with brakes with inferior stuffs and not have a lawsuit.
                                  Chase Bays... More like Wait for days!  Ok I'm done.
                                    It actually got here quickly, albeit with parts that don’t work but you know, silver linings and such
                                      That's kind of what I was alluding to.  Waiting for the right stuff to show up. I'm not even offended my terrible joke didn't go over.  It made me laugh and that's all it needed to do.
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        Yeah, very valid point. I guess I'm just used to not having kits available for things so I'm looking at tried and true patterns that OEs abide by, and tend toward overbuilding things to avoid hassles. A friend had a high pressure PS line fail a couple years back after I warned about using garden variety AN fittings and hose on it, rather than high pressure stuff suited to the application.
                                        After looking at the chase bays high pressure hose for my own curiosity, it looks like they are using crimped fittings (which are much more important for higher pressure) and thicker wall 90s, rather than the thinner tube stuff you commonly see for fuel line and the like. Like you said, probably okay given that they've had the product out there, just wouldn't be the material I'd choose if assembling from scratch (which is irrelevant to this conversation 🤐).
                                          New fitting on its way from chasebays, hoping this one is the golden ticket
