  4. E46 Things
E46 Things
    Price?
    I have glass coverage on my insurance so glass repairs/replacements are no cost/no deductible. The insurance was billed $430
      I dropped my car wash mitt.
      This is not unlike the scene from I Am Legend where the German Shepherd is bit and infected by the zombies and Will Smith has to part with it.
      R.I.P. Mitt Romney
      api9osrny68560.1456252122.jpg?c=2&imbypass=on
        RIP ROM
        Image result for pour out 40oz gif
          Clear->Amber because you always want what you dont have, and it will match the front amber turn signals better. Thanks to @wasnt m3 for the idea
            working on the interior trim as well:
              Vinyl wrap? Looks good!
                Nice job!
                  Keep an eye on that POR-15. I’m sure it’ll be fine but POR usually doesn’t like to adhere to smooth unprotected metal (unless you got the primer/jazz for bare stuff)
                  Vinyl crunch wrap supreme looks better than silver
                    I know what you are talking about. I have had it peel off as a nice single chunk before. I used the acid etch. I have never had an issue when I have used the etching-fluid or whatever one would call it.
                    I have never had a crunch wrap but that sounds so good right now
                      iz that carbon fiber
                        Just a wrap.
                        Finished the dash trim. The door armrests are going to be a challenge. I had enough trouble with the minimal curves on the dash trim
                          The center console and dash trim are easy. I never attempted the arm rests for that very reason. So many curves at the same time.
                            $5 box is a great value, but you're gonna need a catch caddy.
                              Use heat and quality vinyl for the arm rests
                              we did the roof on the evo and it has some really weird/sharp bends by the drip moldings. Just takes some heat and patience
                                Also use knifless tape if you have some edges that are giving you issues. Makes wrapping even easier
                                  Upon further review I decided to apply a second layer of orange film to the lights since in some light settings they looked too yellow.
                                  I like to experiment and feel like the cold shift quality could be improved so I am trying out some Redline D4 ATF.
                                  and after checking @gilber33 ‘s build thread I noticed some ramps that would be very helpful for using the jack points so I picked them up for $38 off Amazon.
                                  I broke the cardinal rule of oil changes by not loosening the fill plug before the drain plug and then struggled for some hours to get the fill plug off. This happened because the E46 M3/E39 M5 fill and drain plugs (according to many internet posts sharing similar tragedies) require a hell of a lot of torque to remove. I had the wrench slip and get the ball rolling down the path of roundness.
                                  I estimate about 120 ft-lb of torque to remove the bolt.
                                  I tried many methods but the Sears Damaged Bolt extractor kit was the saving grace.
                                  Buy a set while you still can. This tool has saved me on so many occasions.
                                  http://www.searshometownstores.com/product/Craftsman-52166-10-pc-Damaged-BoltNut-Remover-Set?store=&preview=3894&isClearanceItem=F&utm_source=google&utm_medium=cpc&adpos=1o1&utm_campaign-SC Shopping&scid=scplp39919909&sc_intid=39919909&gclid=EAIaIQobChMI8MSGhIDZ4wIVyrzACh1sBwBoEAQYASABEgK_w_D_BwE
                                   It took many hours to get it to perform for me because there is barely any hammer space so a mini sledge driving it on at a 45 degree angle is as good as I could get.
                                  The right combination of luck and cursing helped too. So glad to have that behind me now.
                                    I don’t remember how I found those ramps on Amazon, but I wish I knew they existed a long time ago.
                                      A friend of mine uses those little wedge ramps for his car, and they appear to be very convenient!
                                      I have had great success with the rounded head extractor set, though I should really update mine and get the set that goes up to the large sizes!
                                      How are the cold shifts now?
                                        I noticed that the Menards by me is selling Craftsman tool boxes. It would be nice if they started selling Craftsman instead of their masterforce junk.
                                        The more likely scenario is that someone will buy the name and the quality will slide down until it's the same as everything else. Not that Craftsman is amazing. Husky is in the same leauge, but doesn't have a lot of the specialty/automotive stuff.
                                        But I digress.
                                          I have ramps that I never use. Mostly because my civic doesnt fit on any of them.
                                          Those extractors are awesome. I have a brand new set that I bought just in case, and I always forget I have them. Thanks for the reminder!
                                          The amber looks great on the black. 👍 Let us know how the cold shifts feel!
