  4. E46 Things
E46 Things
    Everything is back together and I took it out for a test drive.
    SO MUCH BETTER!
    If you have a clutch delay valve on your E36+ Newer BMW and it has not been removed yet, you need to remove it!
    For  those who have never experienced a CDV or dont know how it feels to have one, basically it delays the engagement of the clutch and makes timing the clutch release and throttle more challenging than it needs to be. It is very hard, if not impossible to get a clean 1-2 shift that doesn’t involve excessively slipping the clutch or giving passengers a jolt.
    It can now be driven smoothly without trying very hard
      New windshield.
      Had 1 rock chip that showed potential to expand rapidly and picked up another rock chip last week that i don't remember hearing. Now I have a clean slate to pick up more rock chips with
        For future reference who did the replacement?
          autoglassfitters.com
            Price?
              Price?
              I have glass coverage on my insurance so glass repairs/replacements are no cost/no deductible. The insurance was billed $430
                I dropped my car wash mitt.
                This is not unlike the scene from I Am Legend where the German Shepherd is bit and infected by the zombies and Will Smith has to part with it.
                R.I.P. Mitt Romney
                api9osrny68560.1456252122.jpg?c=2&imbypass=on
                  RIP ROM
                  Image result for pour out 40oz gif
                    Clear->Amber because you always want what you dont have, and it will match the front amber turn signals better. Thanks to @wasnt m3 for the idea
                      working on the interior trim as well:
                        Vinyl wrap? Looks good!
                          Nice job!
                            Keep an eye on that POR-15. I’m sure it’ll be fine but POR usually doesn’t like to adhere to smooth unprotected metal (unless you got the primer/jazz for bare stuff)
                            Vinyl crunch wrap supreme looks better than silver
                              I know what you are talking about. I have had it peel off as a nice single chunk before. I used the acid etch. I have never had an issue when I have used the etching-fluid or whatever one would call it.
                              I have never had a crunch wrap but that sounds so good right now
                                iz that carbon fiber
                                  Just a wrap.
                                  Finished the dash trim. The door armrests are going to be a challenge. I had enough trouble with the minimal curves on the dash trim
                                    The center console and dash trim are easy. I never attempted the arm rests for that very reason. So many curves at the same time.
                                      $5 box is a great value, but you're gonna need a catch caddy.
                                        Use heat and quality vinyl for the arm rests
                                        we did the roof on the evo and it has some really weird/sharp bends by the drip moldings. Just takes some heat and patience
                                          Also use knifless tape if you have some edges that are giving you issues. Makes wrapping even easier
