  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
  • merlM
    merlM
    merl
    On the rear support for the intake manifold ... There are 2 cutouts that hold them. They both go down to the side of the bell housing on the transmission
    • L
      L
      Laishes
      Brian did we miss those?
        Those were the two connections that I mentioned the e30 guys always get mixed up after doing engine stuff.
        • Brian.B
          Brian.B
          Brian.
          nothing went to my bell housing? I'm confused.
          instagram @howdoyoudrivethat
          • merlM
            merlM
            merl
            These 2 guys
            • Brian.B
              Brian.B
              Brian.
              Okay okay. Those 2 I do remember.
              So if those 2 are switched the car will turn over but won't start?
                You wont get spark if they are switched since the crank position sensor will not send a signal to the ECU and the ECU will not know to discharge the ignition coil.
                • Brian.B
                  Brian.B
                  Brian.
                  Yup. That makes sense now. Fawk.
                  • Brian.B
                    Brian.B
                    Brian.
                    1013907101514732775717111304934586n.j
                    Starting to slap it together!
                    1012311101514734615417111938530145n.j
                    She runs! no leaks or anything. Today was a good day. :) Now to just get my 1.75" to 1.75" ID quick disconnects for the exhaust!
                    • merlM
                      merlM
                      merl
                      Sweet !! Good job today Brian !!
                        What was the issue? were the connectors mixed up?
                        • L
                          L
                          Laishes
                          Dudddeee!!! *highfive*
                          • Brian.B
                            Brian.B
                            Brian.
                            Thanks Merl!
                            Yup, there are 3 connectors, 2 are black, one is grey, I figured the grey one went to the thing that plugs into the intake, but it doesn't, so that was why it didn't fire up. But it fired up yesterday, doing a vinegar clense on the motor with water to get all the build up out, flushing the system a few times, then gunna get it filled with coolant!
                              Brian said:
                               doing the vinegar strokes
                              • Brian.B
                                Brian.B
                                Brian.
                                That's not even close to what I said, so why'd you, put words in my mouth?
                                  Brian said:
                                  I'm super gay
                                  I can quote you however I want to.
                                  :3
                                  • Brian.B
                                    Brian.B
                                    Brian.
                                    I ride my mopeds with pink tassles on the handle bars
                                    :3
                                    Yeah I can too. ;D
                                    • Brian.B
                                      Brian.B
                                      Brian.
                                      BMW's 1 piece straight piped exhaust, i snow a 2 piece slip on/off style. She purrs good. backfires even easier now. ;3
                                      • Brian.B
                                        Brian.B
                                        Brian.
                                        Leaving this here.
                                        1045235101514916910867111315345596n.j
                                          =D
