  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    BMW was all put back together, went to start it, cranked over fine, sounded good, just didn't fire up. So we took the intake/fuel line+rail/air stuff off, going to look where vacuum lines go and shit. Ugh.
    • merlM
      merlM
      merl
      Make sure your reference and speed sensor are not reversed.
        Where are those located?
        • merlM
          merlM
          merl
          On the rear support for the intake manifold ... There are 2 cutouts that hold them. They both go down to the side of the bell housing on the transmission
          • L
            L
            Laishes
            Brian did we miss those?
              Those were the two connections that I mentioned the e30 guys always get mixed up after doing engine stuff.
                nothing went to my bell housing? I'm confused.
                • merlM
                  merlM
                  merl
                  These 2 guys
                    Okay okay. Those 2 I do remember.
                    So if those 2 are switched the car will turn over but won't start?
                      You wont get spark if they are switched since the crank position sensor will not send a signal to the ECU and the ECU will not know to discharge the ignition coil.
                        Yup. That makes sense now. Fawk.
                          1013907101514732775717111304934586n.j
                          Starting to slap it together!
                          1012311101514734615417111938530145n.j
                          She runs! no leaks or anything. Today was a good day. :) Now to just get my 1.75" to 1.75" ID quick disconnects for the exhaust!
                          • merlM
                            merlM
                            merl
                            Sweet !! Good job today Brian !!
                              What was the issue? were the connectors mixed up?
                              • L
                                L
                                Laishes
                                Dudddeee!!! *highfive*
                                  Thanks Merl!
                                  Yup, there are 3 connectors, 2 are black, one is grey, I figured the grey one went to the thing that plugs into the intake, but it doesn't, so that was why it didn't fire up. But it fired up yesterday, doing a vinegar clense on the motor with water to get all the build up out, flushing the system a few times, then gunna get it filled with coolant!
                                    Brian said:
                                     doing the vinegar strokes
                                      That's not even close to what I said, so why'd you, put words in my mouth?
                                        Brian said:
                                        I'm super gay
                                        I can quote you however I want to.
                                        :3
                                          I ride my mopeds with pink tassles on the handle bars
                                          :3
                                          Yeah I can too. ;D
