  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    REKIII said:
    You're gona hate this.......it's because of the rusty fender.
    It's quite possible. Now that it's got the Shark on it, I'm sure that helped.
      Anyone have a 36mm they'd be capable of dropping off? I'm trying to get my front crank bolt off so I can remove the timing cover and get this shit squared away.
        BMW was all put back together, went to start it, cranked over fine, sounded good, just didn't fire up. So we took the intake/fuel line+rail/air stuff off, going to look where vacuum lines go and shit. Ugh.
        • merlM
          merlM
          merl
          Make sure your reference and speed sensor are not reversed.
            Where are those located?
            • merlM
              merlM
              merl
              On the rear support for the intake manifold ... There are 2 cutouts that hold them. They both go down to the side of the bell housing on the transmission
              • L
                L
                Laishes
                Brian did we miss those?
                  Those were the two connections that I mentioned the e30 guys always get mixed up after doing engine stuff.
                    nothing went to my bell housing? I'm confused.
                    • merlM
                      merlM
                      merl
                      These 2 guys
                        Okay okay. Those 2 I do remember.
                        So if those 2 are switched the car will turn over but won't start?
                          You wont get spark if they are switched since the crank position sensor will not send a signal to the ECU and the ECU will not know to discharge the ignition coil.
                            Yup. That makes sense now. Fawk.
                              1013907101514732775717111304934586n.j
                              Starting to slap it together!
                              1012311101514734615417111938530145n.j
                              She runs! no leaks or anything. Today was a good day. :) Now to just get my 1.75" to 1.75" ID quick disconnects for the exhaust!
                              • merlM
                                merlM
                                merl
                                Sweet !! Good job today Brian !!
                                  What was the issue? were the connectors mixed up?
                                  • L
                                    L
                                    Laishes
                                    Dudddeee!!! *highfive*
                                      Thanks Merl!
                                      Yup, there are 3 connectors, 2 are black, one is grey, I figured the grey one went to the thing that plugs into the intake, but it doesn't, so that was why it didn't fire up. But it fired up yesterday, doing a vinegar clense on the motor with water to get all the build up out, flushing the system a few times, then gunna get it filled with coolant!
                                        Brian said:
                                         doing the vinegar strokes
                                          That's not even close to what I said, so why'd you, put words in my mouth?
