  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
  • merlM
    merlM
    merl
    Make sure your reference and speed sensor are not reversed.
      Where are those located?
      • merlM
        merlM
        merl
        On the rear support for the intake manifold ... There are 2 cutouts that hold them. They both go down to the side of the bell housing on the transmission
        • L
          L
          Laishes
          Brian did we miss those?
            Those were the two connections that I mentioned the e30 guys always get mixed up after doing engine stuff.
              nothing went to my bell housing? I'm confused.
              • merlM
                merlM
                merl
                These 2 guys
                  Okay okay. Those 2 I do remember.
                  So if those 2 are switched the car will turn over but won't start?
                    You wont get spark if they are switched since the crank position sensor will not send a signal to the ECU and the ECU will not know to discharge the ignition coil.
                      Yup. That makes sense now. Fawk.
                        1013907101514732775717111304934586n.j
                        Starting to slap it together!
                        1012311101514734615417111938530145n.j
                        She runs! no leaks or anything. Today was a good day. :) Now to just get my 1.75" to 1.75" ID quick disconnects for the exhaust!
                        • merlM
                          merlM
                          merl
                          Sweet !! Good job today Brian !!
                            What was the issue? were the connectors mixed up?
                            • L
                              L
                              Laishes
                              Dudddeee!!! *highfive*
                                Thanks Merl!
                                Yup, there are 3 connectors, 2 are black, one is grey, I figured the grey one went to the thing that plugs into the intake, but it doesn't, so that was why it didn't fire up. But it fired up yesterday, doing a vinegar clense on the motor with water to get all the build up out, flushing the system a few times, then gunna get it filled with coolant!
                                  Brian said:
                                   doing the vinegar strokes
                                    That's not even close to what I said, so why'd you, put words in my mouth?
                                      Brian said:
                                      I'm super gay
                                      I can quote you however I want to.
                                      :3
                                        I ride my mopeds with pink tassles on the handle bars
                                        :3
                                        Yeah I can too. ;D
                                          BMW's 1 piece straight piped exhaust, i snow a 2 piece slip on/off style. She purrs good. backfires even easier now. ;3
