  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 7.2k Views 4 Watching
    Local autox last weekend. Took 1st in XSB and 3rd/69 total drivers, car was co-driven & did well
    @Rekpoint was there too
    Next up is USAIR lapping day
      GoPro crashed and decided to turn hypersmooth crap back on, but here’s a lap at USAIR HPDE
      IMG_9219.MOV
      car did great, weather was a little cooler this time around. Only did the morning run group (4, 20 min sessions for $100).
      New expansion tank seemed to do better, so that’s neat. New tires are now oldish tires
      next event is in wi dells/baraboo
        I love that you are putting this thing through the ringer. So awesome to see! I did a USAIR Autox event long ago in a supercharged civic and had an absolute blast.
          I feel like I’ve missed a lot of events over the past few years (at least in an e30) so I’m trying to make it count ha
            Well it sure seems like you are!
              Forgot to post this, 3/4 RTs had normal wear after the HPDE - 1 got smoked after the lapping day. Unfortunately, not uncommon with the RT. Luckily I have 3 decent condition take offs that I kept (2020) so was able to get it swapped out before the dells autox 8F2F4B34-FDFA-4A6B-A384-851D77D9080C.jpeg
                Dells autox went well, 2 day event. Gf and I codrove the car both days. I took 1st/4 in XSB (7/84 raw) and she took 2nd/4 (14/84 raw) in XSB on day 1. Day 2 I took 1st/5 in XSB (5/92 raw) and she took 2nd/5 in XSB (15/92 raw). The 3 year old RT was in the rear and held its own too ha.
                the lot was extremely bumpy so it was 2 days worth of lockups with no abs, adjusted the bias as much as I felt comfortable with, but just took it as an opportunity to get better at not blowing the fronts off over the large cracks/bumps37C8FD43-753A-453D-ACF4-7A17CBBDD27E.jpeg
                ^the finish on day 1s course was sketchy, in 3rd gear across the line and trying to stop after basically a straight, before the parking lot ended494E65F5-199B-4ED1-B3CD-26F16AA6E244.jpeg20D4E408-7CE4-4B66-957C-A8259448C1C4.jpeg7BDC7E51-51B9-4DE9-BB36-E5CEFFA3C68B.jpeg4CA71BB2-BD96-420F-BBF2-A27F4A4D210C.jpeg
                here are the layouts
                And an outside shot because Intake noise is great
                Pretty much 1 event left before Halloween, night time autox at golden sands. Usually end up taking the beater Miata to that one
                • TDesireT
                  TDesireT
                  TDesire
                  One of my personal favorite e30s! Love this!
                    Long story short, turns out back in late may 2023 I cracked the head on this car which explains the “expansion tank” issues I was having. I raced/codrove it like that for a year without much issue. In April 2024 after an event I decided it was time to dive in as the “expansion tank” issue was getting worse.
                    did a compression test on it and every cylinder checked out great which was weird
                    did a leak down test and cyl 5 took a shit  cracked from exhaust valve to spark plug
                    sourced 2 spare heads, took them to the machine shop & they fixed them all up & then they cracked them both in the fixture when pressure testing lol. (Clamped them wrong)
                    IMG_4260.mov
                    Shit happens and they ended up sourcing 2 heads fairly quickly - just something to note if you’re dropping these off at a shop that normally doesn’t touch these heads, make sure they clamp them down from the head bolt area and aren’t just putting a bar across the top of the head.
                    Raced gf’s Supra for most of 2024 & didn’t have much motivation until recently to get this back together.
                    turns out a few of the bores on the cam trays had some pretty bad scoring so grabbed a set from my spares since I had to reshim the solid lifters anyways
                    this is usually the longest part of the process but it’s pretty straight forward, putting the cams in/out a few times to measure is the longest part
                    also did valve seals because everything was part anyways
                    Just in case anyone is curious since I had to buy spare motors to source heads lol:
                    slapped it back together over the weekend with oem headbolts, Running distilled water&water wetter instead of coolant because I hate cleaning up coolant. Also don’t let me forget for the winter lol.
                    plugged the laptop into ms3, hit the key, everything still worked & it fired right up.
                    beat on it a bit & temps held around 190-195, didn’t have any weird leaks, expansion tank issues, etc -so hopefully it’s good to go. Still need to drop the current oil/filter, bleed brakes, check PS fluid, move fixed seat forward, address dumb valve cover leaks & re tape radiator gaps
                    might run this at the next RA event or just wait for a USAIR lapping day to fully shake it down
                      Glad to see it back on the road 😁
